Everything posted by Mr.Bottomfeeder
Temp Sensing Detect...
Mr.Bottomfeeder replied to Mr.Bottomfeeder's topic in EScribe, Software and Firmware
Hi Zark, thanks for your answer. But that's the problem with using different languages. It's easy to talk past each other. My question was, how the exit in the screen "New Coil?" works - not how to open this screen. I don't open this screen manual by hand, for that I have an extra screen "Coil", what I open manually if needed. But this question is solved meanwhile - I don't use "Goto Parent" or "Goto another Screen: Mainscreen" for leaving "New Coil?"-Screen anymore. Now instead of them I use the functions "Yes, New Coil" and "No, Old Coil" to leave this screen manually. So the Gusub-Stack is not involved in any case and can't produce a "Menu Error - Press Up" anymore. Kind regards -
Version 3.1.6
1,260 downloads
Theme-Style-Collection of my Theme "Mr. Theo Bottomfeeder " - all available in English and German (Deutsch) ---------------------------------------------------------------------- Introduction: ---------------------------------------------------------------------- Here is the newest version of my theme "Mr. Theo Bottomfeeder Black" - Available in English and German GUI language. A little more modern, fewer screens and therefore clearer. But all the necessary features of "Mr. Theo Bottomfeeder Black" are included. INFO: The displayed "AM","PM"-Clock-Errors what are displayed in the upper preview-Screens will not appear in the Theme - that's just a bug in the Forum-Software. ---------------------------------------------------------------------- Short Description - Using of Mainscreens (Full Description see below): ---------------------------------------------------------------------- Power-Profile: -- Coil-Power, Boost-Level, Resistance, Ohm-Lock, Replay and Replay-Warmth are adjustable in Mainscreens -- Thermometer(Temp-Control): not available(Gray) Flame/Snowflake(Preheat): not available(Gray) Lightning(Display-Switch): Switch Boost On/Off - If "On", Boost-Level can be adjusted in Mainscreens Wick (Status of coil): not available(Gray) Temp-Profile: -- Coil-Temp, Coil-Power, Preheat-Temp, Preheat-Power Resistance, Ohm-Lock, Replay and Replay-Warmth are adjustable in Mainscreens -- Thermometer(Temp-Control): Switch Temp-Control On(Thermometer) = Temp-Mode / Off(Crossed out Thermometer) = Power-Mode Flame/Snowflake(Preheat): Switch Preheat On(Flame)/Off(Snowflake) Lightning(Display-Switch): Switch displayed/adjustable values either Coil-Temp and Coil-Power or Preheat-Temp and Preheat-Power Wick (Status of coil): OK(Green)/Error(Red) Main-Colors of displayed values in mainscreens (only in the colored Text-Versions No. 1 - 8 and 17 - 20) Red: Temp-Mode - Coil-Power and Coil-Temp Yellow: Temp-Mode - Preheat-Power and Preheat-Temp Green: Power-Mode - Boost deactivated Light Blue: Power-Mode - Boost activated Orange: While Charging Pack-Level and Pack-Voltage White: Replay active Replay: Off: Filled red Rectangle On, but still initializing: Two red vertical Bars On, ready for Replay: Red filled Circle Replaying: Red filled Triangle ---------------------------------------------------------------------- Kurz-Anleitung - Benutzen der Mainscreens (Vollständige Anleitung siehe unten): ---------------------------------------------------------------------- Power-Profil: -- In den Mainscreens sind Coil-Power, Boost-Level, Widerstand, Ohm-Lock, Replay und Replay-Wärme einstellbar -- Thermometer(Temp-Control): Nicht verfügbar(Grau) Flamme/Schneeflocke(Preheat): Nicht verfügbar(Grau) Blitz(Anzeige-Umschalter): Schaltet Boost Ein/Aus - Wenn "Ein", kann der Boost-Level in den Mainscreens geändert werden Wicklung (Zeigt Coil-Status ) Nicht verfügbar(Grau) Temperatur-Profil: -- In den Mainscreens sind Coil-Temp, Coil-Power, Vorheiz-Temp, Vorheiz-Power, Widerstand, Ohm-Lock, Replay und Replay-Wärme einstellbar -- Thermometer(Temp-Control): Schaltet Temp-Control Ein(Thermometer) = Temperatur-Modus / Aus(DurchgestrichenesThermometer) = Power-Modus Flamme/Schneeflocke: Schaltet Vorheizen Ein(Flamme)/Aus(Schneeflocke) Blitz(Anzeige-Umschalter): Schaltet angezeigte/einstellbare Werte entweder Coil-Temp und Coil-Power oder Vorheiz-Temp und Vorheiz-Power Wicklung (Zeigt Coil-Status): OK(Grün)/Fehler(Rot) Haupt-Farben der Werte in Mainscreens (nur in den Farb-Text-Versionen No. 1 - 8 and 17 - 20) Rot: Temp-Mode - Coil-Power und Coil-Temp Gelb: Temp-Mode - Vorheiz-Power und Vorheiz-Temp Grün: Power-Mode - Boost deaktiviert Hellblau: Power-Mode - Boost aktiviert Orange: Während des Ladens Akku-Level und Akku-Spannung Weiss: Replay aktiv Replay: Aus: Gefülltes rotes Quadrat Ein, aber noch nicht initialisiert: Zwei rote senkrechte Balken Ein, bereit für Replay: Roter gefüllter Kreis Replay aktiv: Rotes gefülltes Dreieck ---------------------------------------------------------------------- Versions ---------------------------------------------------------------------- Theme-Variations (all same functions, but different Backgrounds, Fonts and Colors) with their possible Outputs(depending on the settings) - see following pictures - English GUI = even numbers - German GUI = odd numbers • Version A has a lockscreen with Zodiac-Circle, Screen-Backgrounds in Black (No. 1, 2, 5, 6) • Version B has a "Broken Wall" Lockscreen and Screen-Backgrounds with floral shapes (No. 3, 4, 7, 8 ) • Version C has a "Starshine" Lockscreen and Screen-Backgrounds with blue pattern (No. 17, 18, 19, 20 ) -> No. 20 is Displayed in upper Preview as Default example • Version A, B and C in "B&W"-Style have in contrast to the standard colored Text-fields all text in White (No. 9, 10, 11, 12, 21, 22, 23, 24) • Version A, B and C in "Gray"-Style have in contrast to the standard colored Text-fields all text in different gray-colors (No. 13, 14, 15, 16, 25, 26, 27, 28) I suspect that the versions with colored text output are easier to understand and a little easier to use than the other versions. But I think that the purist steam fans prefer the black and white and gray versions rather than the other versions colored in chewing gum colors. Even if these variations are not so intuitively understandable. Because these themes don't look that playful. Or what do you think - which versions do you prefer? I would appreciate a few more comments and / or criticisms on this theme and its versions. Theme Variationen (alle haben dieselben Funktionen, aber unterschiedliche Hintergründe, Schriftarten und Farben) mit deren möglichen Ausgaben(abhängig der Einstellungen) - siehe folgende Bilder - Englische GUI = gerade Nummern - Deutsche GUI = ungerade Nummern • Version A hat einen Lockscreen mit Tierkreiszeichen, Screen-Hintergrund in schwarz (Nr. 1, 2, 5, 6) • Version B hat einen "Gebrochene Wand"-Lockscreen, Screen-Hintergrund mit floralen Mustern(Nr. 3, 4, 7, 8 ) • Version C hat einen "Sterne"-Lockscreen, Screen-Hintergrund mit blauem Muster(Nr. 17, 18, 19, 20 ) -> Nr. 20 ist als Default-Beispiel oben in der Vorschau dargestellt • Version A, B und C in "B&W"-Stil haben anstelle der standardmässig farbigen Textausgaben alle Textfelder in weisser Schrift (Nr. 9, 10, 11, 12, 21, 22, 23, 24) • Version A, B und C in "Gray"-Stil haben anstelle der standardmässig farbigen Textausgaben alle Textfelder in verschiedenen Grautönen (Nr. 13, 14, 15, 16, 25, 26, 27, 28) Ich vermute, dass die Versionen mit colorierten Textausgaben leichter verständlich und etewas leichter zu bedienen sind, als die anderen Versionen. Aber ich denke, dass die puristischen Dampf-Freunde eher die S/W- und die Grau-Versionen bevorzugen, als die in Kaugummi-Farbenen colorierte anderen Versionen. Auch, wenn diese Variationen nicht so intuitiv verständlich sind. Weil diese Themes nicht so verspielt aussehen. Oder was meint Ihr - welche Versionen bevorzugt Ihr? Über ein paar mehr Kommentare und/oder Kritiken zu diesem Theme und seinen Versionen würde ich mich freuen. ---------------------------------------------------------------------- "Mr. Theo Bottomfeeder LED" - Available in English and German "Mr. Theo Bottomfeeder LED" - Version A - (No. 1, 2) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder LED" - Version B - (No. 3, 4) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder LED" - Version C - (No. 17, 18) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder Easy Readable" - Available in English and German "Mr. Theo Bottomfeeder Easy Readable" - Version A - (No. 5, 6) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder Easy Readable" - Version B - (No. 7, 8 ) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder Easy Readable" - Version C - (No. 19, 20 ) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder LED - Black&White" - Available in English and German "Mr. Theo Bottomfeeder LED - Black&White - Version A - (No. 9, 10) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder LED - Black&White - Version C - (No. 21, 22) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder Easy Readable Black&White" - Available in English and German "Mr. Theo Bottomfeeder Easy Readable Black&White" - Version B - (No. 11, 12) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder Easy Readable Black&White" - Version C - (No. 23, 24) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder LED Gray" - Available in English and German "Mr. Theo Bottomfeeder Easy Readable Gray" - Version A - (No. 13, 14) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder Easy Readable Gray" - Version C - (No. 25, 26) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder Easy Readable Gray" - Available in English and German "Mr. Theo Bottomfeeder Easy Readable Gray" - Version B - (No. 15, 16) Lockscreen - Mainscreen 1 - Mainscreen 2 "Mr. Theo Bottomfeeder Easy Readable Gray" - Version C - (No. 27, 28) Lockscreen - Mainscreen 1 - Mainscreen 2 *** English Description (Deutsche Beschreibung siehe unten) *** ---------------------------------------------------------------------- Supports: 2 choseable Mainscreens - Replay - Powerbank - up to 4 Batteries ---------------------------------------------------------------------- English and German GUI-Languages available - each Language in two versions: Version A with zodiac-lockscreen and black backgrounds, Version B with "broken-wall"-lockscreen and floral screen-backgrounds (see pictures below) This Theme-Version was created by: Author: Hubert Allgäuer (Alias "Mr. Bottomfeeder"), Lake of Constance, Germany with using the program: "EScribe Suite V 2.0 with Service Pack 15.1" Here my second and completely reworked version of this Theme for the DNA75C/DNA250C (tested on Therion BF 75C, Rebel BF 75C, VT200, Boxer BF DNA250C, Lost Vape Drone BF 250C) available in english and german language. It is my most comfortable, informative and comprehensive theme so far. Developed for all who want to have knowledge about all parameters of the DNA. No playful pictures, only information and all parameters of the DNA chip can be called up and displayed. These are arranged in a unique, easily understandable and intuitive way. In this Theme, first time the exact status of the coil is determined and, in the event of problems that prevent Temp-Control, the system automatically switches to power mode and the user will be informed by a symbol in Mainscreen about the problem. The user may select one of two Mainscreens: Mainscreen 1 "Mad Eye Moody" (bigger chars but less information) and Mainscreen 2 "Hawkeye Pierce" (smaller chars but more information) This theme is easily viewed in dark and bright background. Well suited for developers and those who want to have full control over all the settings of the DNA chip as well as for all casual users. Hoping everything works well - if you find some problems or malfunctions or having wishes or questions, please feel free to drop me a note here. *** I would appreciate your comments on the usability of this topic, your thoughts on this topic, your suggestions for improvement, and your wishes for further updates. A coder's life almost made up of comments and suggestions! 😉 *** Wishing you have fun with this theme Greetings Mr. Bottomfeeder P.S. Many thanks to the user "Wayneo" for his kind help in finding bugs, his hints for improving this Theme and his corrections to improve the readability of this manual!😃😃😃 ** The attached files below this manual contains this manual as TXT-File and my favorite selection of 30 Lockscreen-Pictures. ** ---------------------------------------------------------------------- Information: ---------------------------------------------------------------------- For using the Theme "Mr. Theo Bottomfeeder LED" with the new Replay-Mode, you need the following Firmware on your Device. Otherwise this Theme can not be installed. Needed Firmware on the device: "1.1 SP 33.2 INT" or later version ---------------------------------------------------------------------- Manual ---------------------------------------------------------------------- ++ General ++ Three different kind of Buttons • "X" (red cross symbol - not active) and "check mark"(green - Active) Not switchable - only as pure information for the user about the status of a value • "Green button" and "Red button" Switchable button On (green) / Off (red) to switch an option On / Off • "Blue1 button“ and "Blue2 button“ Switchable button to toggle between two states ++ Screens ++ • Don't be surprised, the "Profile" screen automatically changes between "Temp-Profile" and "Watt-Profile" depending on the selected mode with the appropriate input and selection options. • All screens only show the elements and setting options that are possible with the current settings. • A small "Lock"-Symbol in the Mainscreens next to the Ohm-Value allows switching Ohm-Lock-On/Off directly in Mainscreens. • Automatic fallback to Power-Mode if Temp-Sense error detected • Information-text in taskbar describes function of each selected element ++ Used Abbreviations ++ • TSM = Temp Sense Material (wire is useable for Temp-Control) • TSD = Temp Sense Detect (Useable Temp-Control) • PWR = Power-Mode • TCM = Temp-Control-Mode • PBE = Preheat/Boost • TPR = Temp-Protect • TC = Temp-Control • PH = Preheat ++ Mainscreen 1 "Mad Eye Moody" (bigger chars but fewer information) - Icon: Mad-Eye-Moodys Eye and Mainscreen 2 "Hawkeye Pierce" (smaller chars but more information) - Icon: Hawks-Head: ++ • Upper side: Voltage-Value >>clicking opens Screen "USB", if connected - otherwise opens screen "Pack"<< • Upper side: Pack-Level as graphic bar display >>clicking opens Screen "USB", if connected - otherwise opens screen "Pack"<< --Selecting what to show: By clicking the button "Bar" or "Digital" in the screen "Display" - Selected status will be showed-- Voltage-state is displayed in different colors - depending on the battery level (green> = 66%, yellow> = 33% and <66%, red <33%). Charged full and Pack-Empty-Alert when using is displayed in relevant Screens ++Only in Mainscreen 2 "Hawkeye Pierce"++: Below Pack-Display: • Profile and Material >>clicking one to select a Profile or Material<< • Date and Time >>clicking one opens Screen "System"<< • Big Time >>clicking opens Screen "System"<< --Selecting what to show: By de-/activating the two buttons "In Main" in the screen "System" - Left button = switching Profile and Material (red) or time display (green), right button = if time display is activated switching between date and time (Blue1) or big time (Blue2)-- **If firing, a flame symbol appears instead at this place** ++Only in Mainscreen 2 "Hawkeye Pierce"++: Above the lower information line: • Left display: "Volt/Watt" - Coil voltage/coil power • Right display: "Ampere/Ohm" - Coil current/Coil Resistant • Lower display: "Puff/Puffs" - duration of the current Puff / total number of Puffs since reset --The contents for output values for the lower three fields can be choosen in Screen "Display" - the choosen status will be displayed-- ++ Only in Mainscreen 1 "Mad Eye Moody" ++: While firing, a flame symbol appears instead of the lower six Symbols at this place ++ Mainscreen 1 "Mad Eye Moody" and Mainscreen 2 "Hawkeye Pierce" ++ Icon below right - Lockscreen (Icon "Bed") or "Mad Eye Moodys Eye" or "Hawks-Head" Function: • Icon: "Mad Eye Moodys Eye" or "Hawks-Head" Switches in all Screens expect in the Lockscreen and active Mainscreen to the active Mainscreen **Due to the limitation of the software, the Mainscreen 1 "Mad Eye Moody" will always be displayed after unlocking the device, even if Mainscreen 2 "Hawkeye Pierce" is activated as Mainscreen. In these case, the Mainscreen 2 "Hawkeye Pierce" can be accessed again by simply clicking the Icon "Hawks-Head" in the lower right Edge in Mainscreen 1.** -- Temporary or static specify which screen is defined as Mainscreen by de-/activating the buttons for "Mainscreen" in the screen "Menu 1"-- • Icon "Bed" Switches in active Mainscreen into the Lockscreen ---------------------------------------------------------------------- Symbols (Mainscreen 1 "Mad Eye Moody" and Mainscreen 2 "Hawkeye Pierce") ---------------------------------------------------------------------- "Thermometer" with three modes • In Power-Mode Picture (Thermometer) - Thermometer greyed out >> Clicking opens the "Coil" screen << • In TC-Mode – regular Switch (colored Thermometer) Temp-Protect On(Temp-Mode) / Off(Power-Mode) (Note: Switching this function takes approx. 5 seconds until the change is accepted and displayed by the DNA - this is normal) - Colored Thermometer Temp-Protect is switched on and works >> Clicking turns Temp-Protect off << - Crossed out thermometer Temp-Protect is switched off >> Clicking turns Temp-Protect on << • In TC-Mode - Special: Picture (Sign) - Crossed out "D" Coil without Temp Sensing Detect (coil with contact problem - fluctuating coil resistance) >> Clicking opens the "Coil" screen << - Crossed out "M" Coil without Temp Sensing Material (wrong coil wire for selected temp control profile) >> Clicking opens the "Coil" screen << "Flash/Lightning Bolt" with two modes • In Power-Mode (or in TC-Mode with deactivated Temp-Control) Switch (Green or Blue flash) is displayed to switch Boost on and off - Green flash Boost is deactivated Display in green color - Top: Coil-Power - Bottom: Label "Power" - Blue flash Boost is activated Display in blue color - Top: Coil-Power - Bottom: Boost-Level >> Switch Boost On/Off by clicking the flash symbol << • In TC-Mode Switch (red or yellow flash) is displayed for switching displaying and setting either Coil-Temp/Coil-Power or Preheat-Temp/Preheat-Power in both Mainscreens - Red flash: Display in red color - Top: Coil Temperature - Bottom: Coil-Power - Yellow flash: Display in yellow color - Top: Preheat Temp - Bottom: Preheat-Power >> Switch Preheat-Display-Values by clicking the flash symbol << If Temp-Protect is deactivated in TC-Mode: Display in orange color - Top: Coil-Power - Bottom: Boost-Level. If Display in white color, then something with the coil doessn't match (check other infos on Mainscreen then) "Flame / Snowflake" with two modes • In Power Mode Picture (Flame) - Gray Flame Power Mode is activated >> Clicking opens the "Profile" screen << • In TC Mode Switch (Flame / Snowflake) Is displayed for switching Preheat On/Off >> Switch Preheat On/Off by clicking the flash symbol << - Colored Flame Preheat is activated - Snowflake Preheat is deactivated >> Clicking toggles Preheat On/Off << "Coil" with two modes • In Power Mode Picture (Coil) - Grayed-Out Coil with both pins down >> Clicking opens the "Profile" screen << • In TC-Mode Picture (Coil) - Green Coil with both pins down Temp-Sense-Material and Temp-Sense-Detect recognized (fully functioning TC-Mode, TC wire with activated Temp-Control) >> Clicking opens the "Profile" screen << - Red Coil with left pin up No Temp-Sense-Material, but Temp-Sense-Detect detected (usually should never actually happen - but what is usual 🙂 ) >> Clicking opens the "Profile" screen << - Red Coil with right pin up Temp-Sense-Material, but no Temp-Sense-Detect detected (Coil with contact problem - fluctuating coil resistance) >> Clicking opens the "Profile" screen << - Red Coil with both pins up Neither Temp-Sense-Material nor Temp-Sense-Detect detected (no resistance wire selected for TC-Mode) >> Clicking opens the "Profile" screen << Replay: Bottom Center: "Replay"-Buttons (like on a Cassette-Recorder). • Stop-Symbol (red filled square) Replay is deactivated • Pause-Symbol (two red vertical bars): Replay is on but not initialized yet (no puff recorded) - i.e after each unlock from lockscreen • Record-Symbol (a filled red circle): Replay has recorded a puff and is ready for playing • Play-Symbol (a filled red triangle): Replay is playing When Replay is Playing, the words "Replay" and "active" are displayed in big yellow chars in both Mainscreens. Additional a graphic bar display for control Replay warmth is shown. Using the Replay-Mode: The Replay-Mode is changeable seperately for each Profile. It can be activated directly in this theme, if choosing in the "Replay"-Page ("Menu 1" - "Replay"). Also the activation of the Replay-Mode can be done in the Profile-Settings in the EScribe-Program and uploading the changed Profile-Settings onto your device. If the Replay-Mode is activated, the standard grey Replay-Symbol on both Main-Pages of this theme is changing into a "Pause"-Symbol (two red standing bars - similar the "Pause"-Button on a tape-machine). Recording a puff for Replay: If the Replay-Mode is activated, you have to puff some times for initializing the Replay-Mode. As soon the Replay-Mode is prepared for recording a puff, the "Pause"-Symbol on Mainscreen changes into a red filled circle (like the "Record"-Button on a tape-machine). Now you can click the "Record"-Symbol after you had a puff that fully meets your expectations. Play a recorded puff in Replay (always repeated): As soon, as a puff is recorded, the Pause-Symbol changes into a red Triangle "Play"-Symbol (also like the "Play"-Button on a Tape-Machine). Additionally the words "Replay" "active" are displayed in big yellow chars on both Main-Screens of the Theme. That shows, the previous recorded puff will be repeated endless now. Stop Replay-Mode: For ending the Replay-loop, just click onto the red "Play"-Symbol. The yellow "Replay"-Name dissappears from the Main-Screens and the Replay-Symbol changes back into the red filled Circle "Record"-Symbol. The Device went back into normal using-mode now. By clicking the "Record"-Symbol again, the last puff will be saved and the Replay-Mode changes into the Play-Mode. All other elements should be self-explanatory. ---------------------------------------------------------------------- REPLAY ---------------------------------------------------------------------- BE AWARE! Never enable the "Puff saved, playing" checkbox in the profile settings of your EScribe program. Check this setting if Replay does not work as expected. If activating the checkboxes "Puff saved, playing" at this point, the Replay mode would be activated - but without a recorded favourite puff, which could cause malfunctions. So just activate the checkbox "Use replay on this profile". --------------------------------------------------------------------- Developer Informations ---------------------------------------------------------------------- Used Toggles: Toggle 1: Voltage / Power - Display in Main 2 (Choseable in Screen "Display") Toggle 2: Current / Ohms - Display in Main 2 (Choseable in Screen "Display" Toggle 3: Puff / Puffs - Display in Main 2 (Choseable in Screen "Display") Toggle 4: Pack Digital / Bar - Display in Main 1 and 2 (Choseable in Screen "Display") Toggle 5: Mainscreen 1 or 2 - As temporary or static state - (Choseable in Screen "Menu1") Toggle 6: Coil / Preheat - shows either Coil-Temp and Coil-Power or Preheat-Temp and Preheat-Power - Displayed in Mainscreen "Mad Eye Moody" and "Hawkeye Pierce" (Choseable in Mainscreen "Mad Eye Moody" and "Hawkeye Pierce", if Temp-Control is active) by switching "Flash"-Icon Toggle 7: Time Yes/No - Display in Main 2 (Choseable in Screen "System") Toggle 8: Time / Time and Date - Display in Main 2 (Choseable in Screen "System") --------------------------------------------------------------------- Whats new in this version ---------------------------------------------------------------------- 3.1.6 Display-Error in Wattage-Mode repaired - Pack-Empty wasn't displayed correctly ---------------------------------------------------------------------- German Translation ---------------------------------------------------------------------- Hier die Nachfolge-Version meines Themes "Mr. Theo Bottomfeeder LED" - verfügbar in deutscher und englischer GUI-Sprache. Etwas moderner, weniger Screens und dadurch übersichtlicher. Aber dennoch sind alle notwendigen Funktionen von "Mr. Theo Bottomfeeder Black" enthalten. Die angezeigten "AM", "PM"-Uhrzeit-Fehler in der obigen Vorschau existieren im realen Theme nicht. Diese Falsch-Anzeigen kommen von der Forum-Software Deutsche Beschreibung (English Description see upper text) ---------------------------------------------------------------------- Unterstützt: 2 auswählbare Mainscreens - Replay - Powerbank - bis zu 4 Akkus ---------------------------------------------------------------------- - Englische und deutsche GUI-Sprachen verfügbar - - jede Sprache in zwei Versionen: Version A mit Tierkreis-Lockscreen und schgwarzen Hintergründen, Version B mit "gebrochene-Wand"-Lockscreen und floralen Screen-Hintergründen (siehe Bilder unten) Diese Theme-Version wurde erstellt von: Autor: Hubert Allgäuer (Alias "Mr. Bottomfeeder"), Bodensee, Deutschland mit dem Programm: "EScribe Suite V 2.0 mit Service Pack 15.1" Hier die komplett überarbeitete V2 meines Themes für die DNA 75C/DNA250C (getestet mit Therion BF 75C, Rebel BF 75C, VT200, Boxer BF DNA250C, Lost Vape Drone BF 250C) in englischer und deutscher Sprache. Es ist mein bislang komfortabelstes, informativstes und umfassendstes Theme. Entwickelt für alle, die über sämtliche Parameter der DNA Bescheid wissen wollen. Keine verspielten Bildchen, nur Informationen und sämtliche Parameter des DNA-Chips abrufbar und angezeigt. Aber diese dafür in einzigartiger Weise leicht verständlich und intuitiv bedienbar arrangiert. Der Benutzer kann zwischen zwei Mainscreens auswählen: Mainscreen 1 "Mad Eye Moody" (grössere Zeichen aber weniger Informationen) und Mainscreen 2 "Hawkeye Pierce" (kleinere Zeichen aber mehr Informationen) In diesem Theme wird erstmals der exakte Status des Coils bestimmt und bei Problemen, welche die TempControl verhindern, automatisch auf den Power-Modus umgeschaltet und der Benutzer per Symbol auf dem Mainscreen über das Problem informiert. Dieses Theme ist in dunkler und heller Umgebung leicht abzulesen und nicht nur gut geeignet für Entwickler und diejenigen, die die volle Kontrolle über alle Einstellungen des DNA-Chips haben wollen, sondern auch für alle normalen Benutzer. Ich hoffe, dass alles gut funktioniert - wenn Ihr Probleme oder Fehlfunktionen feststellt oder Wünsche oder Fragen habt, können Ihr mir gerne eine Nachricht hinterlassen. *** Über Eure Kommentare zur Brauchbarkeit dieses Themes würde mich mich sehr freuen, auch über Eure Meinung zu diesem Theme, über Verbesserungsvorschläge und Eure Wünsche für künftige Updates. Ein Entwickler lebt schliesslich von Kommentaren und Vorschlägen 😉 *** Viel Spaß mit diesem Theme Beste Grüße Mr. Bottomfeeder P.S. Vielen Dank an den Benutzer "Wayneo" für seine freundliche Hilfe bei der Suche nach Fehlern, seine Hinweise zur Verbesserung dieses Themes und seine Korrekturen, um die Lesbarkeit dieser Beschreibung zu verbessern! 😃😃😃 ** Die unten angefügten Dateien beinhalten diese Anleitung als TXT-Datei und 30 meiner Lieblings-Lockscreens ** ---------------------------------------------------------------------- Information: ---------------------------------------------------------------------- Zur Verwendung des Themes "Mr. Theo Bottomfeeder LED" und des neuen Replay-Modus benötigt Ihr folgende Firmware auf Eurem Gerät. Ansonsten kann dieses Theme nicht installiert werden. Benötigte Firmware auf dem Gerät: "1.1 SP 33.2 INT" oder höhere Version. ---------------------------------------------------------------------- Bedienung ---------------------------------------------------------------------- ++ Generell ++ Drei unterschiedliche Schalter • "X"(rotes Kreuz-Symbol):Nicht aktiv und "Häkchen"(Grün):Aktiv Nicht schaltbare, reine Information für den User über den Zustand eines Wertes • Schaltfläche "Grüner Knopf" und "Roter Knopf" Umschaltbarer Schaltfläche Ein(Grün)/Aus(Rot) um eine Option Ein-/Auszuschalten • Schaltfläche "Blau1" und "Blau2" Umschaltbarer Schalter, um zwischen zwei Zuständen umzuschalten • Automatisches fallback in den Power-Mode, wenn Temp-Control Fehler • Informations-Text in der Taskbar beschreibt die Funktion jedes selektierten Elements ++ Screens ++ • Wundern Sie sich nicht - das Screen "Profil" wechselt in seiner Darstellung automatisch je nach gewähltem Modus zwischen "Temp-Profil" und "Watt-Profil" mit den jeweils passenden Eingabe- und Auswahlmöglichkeiten. • In allen Screens werden jeweils nur die Elemente und Einstellmöglichkeiten angezeigt, die mit den aktuellen Einstellungen möglich sind. • Ein kleines "Schloss"-Symbol neben der Ohm-Anzeige erlaubt das Ein-/Ausschalten des Ohm-Locks direkt in den Mainscreens. ++ Benutzte Abkürzungen ++ • TSM = Temp Sense Material (Temperatur-Überwachungs geeigneter Draht) • TSD = Temp Sense Detect (Funktionierende Temperatur Überwachung) • PWR = Power-Mode (Watt-Modus) • TCM = Temperatur-Überwachungs-Modus • PBE = Preheat/Boost • TPR = Temp-Protect • TC = Temperatur-Kontrolle • VH = Vorheizen ++ Mainscreen 1 "Mad Eye Moody" (grössere Zeichen, aber weniger Informationen) - Symbol: Mad-Eye-Moodys Auge und Mainscreen 2 "Hawkeye Pierce" (kleinere Zeichen, aber mehr Informationen) - Symbol: Falkenkopf: ++ • Oben: Akku-Spannung >>Klick öffnet Screen "USB", wenn verbunden - andernfalls wird Screen "Akku" geöffnet<< • Oben: Graphische Balken-Anzeige für Akku-Level >>Klick öffnet Screen "USB", wenn verbunden - andernfalls wird Screen "Akku" geöffnet<< --Auswählen was angezeigt werden soll: Durch Anklicken der Schaltfläche "Balken" oder "Digital" im Screen "Anzeige" - Der ausgewählte Status wird jeweils angezeigt -- Der Akkuzustand wird in verschiedenen Farben angezeigt - abhängig vom Akku-Level (Grün >= 66%, Gelb >= 33% und <66%, Rot < 33%) Der Akku-Voll- und Akku-Leer-Alarm wird bei der Verwendung in den entsprechenden Screens angezeigt ++ Nur in Mainscreen 2 "Hawkeye Pierce"++: Unterhalb der Akku-Anzeige: • Profil und Material >> Anklicken zur Auswahl eines Profils oder Material << • Datum und Uhrzeit >> Anklicken öffnet Screen "System" << • Grosse Uhrzeit >> Anklicken öffnet Screen "System" << --Auswählen was angezeigt werden soll: durch De-/Aktivieren der zwei Schaltflächen "In Main" im Screen "System" - Linker Button = Umschalten Profil und Material (rot) oder Zeitanzeige (grün), rechter Button = Bei aktivierter Zeitanzeige Umschalten Datum und Zeit (Blau1) oder grosse Uhrzeit (Blau2)-- **Wenn gefeuert wird erscheint stattdessen ein Flammensymbol** ++ Nur in Mainscreen 2 "Hawkeye Pierce"++: Über der unteren Informations-Zeile: • Linke Anzeige: "Volt/Watt" - Coil-Spannung/Coil-Leistung • Rechte Anzeige: "Ampere/Ohm" - Coil-Strom/Coil-Widerstend • Untere Anzeige: "Zug/Züge" - Dauer des aktuellen Zugs/Gesamtanzahl der Züge seit Reset --Die Inhalte der Ausgabewerte für die unteren drei Felder können im Screen "Anzeige" ausgewählt werden - der jeweilige Status wird angezeigt-- ++ nur in Mainscreen 1 ("Mad Eye Moody")++: Während gefeuert wird erscheint statt der sechs unteren Symbolen ein Flammensymbol ++Mainscreen 1 "Mad Eye Moody" und Mainscreen 2 "Hawkeye Pierce"++ Symbol unten rechts - Lockscreen (Symbol "Bett") oder "Mad Eye Moodys-Auge") oder "Falkenkopf" Funktion: • Symbol: "Mad Eye Moodys Auge" oder "Falkenkopf". Schaltet in allen Screens (ausser Lockscreen und Mainscreens) zu dem aktiven Mainscreen. **Bedingt durch die Limitation der Software wird nach dem Unlock des Gerätes immer das Mainscreen 1 angezeigt, auch wenn Mainscreen 2 ("Hawkeye Pierce") als Mainscreen aktiviert ist. In diesem Fall kann das Mainscreen 2 ("Hawkeye Pierce") durch einfaches Anklicken des unteren rechten Symbols "Falkenkopf" im Mainscreen 1 wieder aufgerufen werden.** -- Temporäres oder statisches festlegen, welche Screen als Mainscreen definiert wird, durch De-/Aktivieren der Schaltflächen für "Mainscreen" im Screen "Menu 1" -- • Symbol "Bett" Schaltet im aktiven Mainscreen in das Lockscreen ---------------------------------------------------------------------- Symbole (Mainscreen 1 "Mad Eye Moody" und Mainscreen 2 "Hawkeye Pierce"): ---------------------------------------------------------------------- "Thermometer" mit drei Modi • Im Power-Modus Bild (Thermometer) - Thermometer ausgegraut, wenn Power-Modus eingestellt ist >>Anklicken öffnet Screen "Coil"<< • Im TC-Modus – Normal Schalter (Thermometer) Temp-Protect Ein(Temperatur-Modus) / Aus(Power-Modus) (Anmerkung: Das Umschalten dieser Funktion dauert ca. 5 Sek., bis die Änderung vom DNA übernommen und angezeigt wird - dies ist normal) - Farbiger Thermometer Temp-Protect eingeschaltet ist und funktioniert >>Anklicken schaltet Temp-Protect aus<< - Durchgestrichenes Thermometer Temp-Protect wurde ausgeschaltet >>Anklicken schaltet Temp-Protect an<< • Im TC-Modus – Spezial Bild (Buchstabe) - Durchgestrichenes "D" Coil ohne Temp Sensing Detect erkannt wurde (Verdampfer mit Kontakt-Problem - schwankender Coil-Widerstand) >>Anklicken öffnet Screen "Coil"<< - Durchgestrichenes "M Coil ohne Temp Sensing Material (falscher Coildraht für gewähltes Temp-Control-Profil) >>Anklicken öffnet Screen "Coil"<< "Blitz" mit zwei Modi • Im Power(Watt)-Modus (oder im TC-Mode mit deaktiviertem Temp-Control) Schalter (Grüner oder Blauer Blitz) wird angezeigt, um Boost (nur im Power-Modus) ein- und auszuschalten - Grüner Blitz wird angezeigt (Boost Aus) Grüne Anzeige - Oben: Coil-Power, Unten: Label "Power" - Blauer Blitz wird angezeigt (Boost Ein) Blaue Anzeige - Oben: Coil-Power, Unten: Boost-Level >>Umschalten Boost Ein/Aus durch Anklicken des Blitz-Symbols<< • Im TC-Modus Schalter (Roter oder Gelber Blitz) wird angezeigt, um die Haupt-Anzeige in beiden Mainscreens auszuwählen - Roter Blitz: Rote Anzeige Oben: Coil-Temperatur - Unten: Coil-Power - Gelber Blitz: Gelbe Anzeige Oben: Vorheizen-Temperatur - Unten: Vorheizen-Power >>Umschalten der Anzeige-Werte durch Anklicken des Blitz-Symbols<< Wenn im TC-Modus die Temp-Protect deaktiviert ist, wird in oranger Farbe Oben: Coil-Power und Unten: Boost-Level angezeigt. Werden die Werte auf dem Display in weisser Schrift angezeigt, dann stimmt etwas mit dem Coil nicht (vgl. die anderen Informationen auf dem Mainscreen) "Flamme/Schneeflocke" mit zwei Modi • Im Power-Modus Bild (Flamme) - Graue Flamme, wenn Power-Modus aktiviert ist >>Anklicken öffnet Screen "Profil"<< • Im TC-Modus Schalter (Flamme/Schneeflocke) Um Vorheizen ein und auszuschalten - Farbige Flamme, wenn im TC-Modus Vorheizen aktiviert ist - Schneeflocke, wenn im TC-Modus Vorheizen deaktiviert ist >> Anklicken schaltet Vorheizen Ein/Aus) << "Wicklung" mit zwei Modi • Im Power-Modus Bild (Wicklung) - Ausgegraute Wicklung mit beiden Pins nach unten >>Anklicken öffnet Screen "Profil"<< • Im TC-Modus Bild (Wicklung) - Grüne Wicklung mit beiden Pins nach unten: Temp-Sense-Material und Temp-Sense-Detect erkannt (voll funktionierender TC-Modus, TC-Draht mit aktivierter Temp-Control) >>Anklicken öffnet Screen "Profil"<< - Rote Wicklung mit linkem Pin nach oben: Kein Temp-Sense-Material, aber Temp-Sense-Detect erkannt (Sollte eigentlich nie vorkommen) >>Anklicken öffnet Screen "Profil"<< - Rote Wicklung mit rechtem Pin nach oben: Temp-Sense-Material, aber kein Temp-Sense-Detect erkannt (Verdampfer mit Kontaktproblem - schwankender Coil-Widerstand) >>Anklicken öffnet Screen "Profil"<< - Rote Wicklung mit beiden Pins nach oben: Weder Temp-Sense-Material noch Temp-Sense-Detect erkannt (Falscher Draht für Temp-Control ausgewählt) >>Anklicken öffnet Screen "Profil"<< Replay: Unten Mitte: "Replay" -Buttons (wie bei einem Kassetten-Recorder). • Stop-Symbol (rotes gefülltes Quadrat) Replay ist deaktiviert • Pause-Symbol (zwei rote vertikale Balken) Replay ist aktiviert aber noch nicht initialisiert (Kein aufgezeichneter Zug) - z.B. nach jedem Aufwecken aus dem Lockscreen • Record-Symbol (ein gefüllter roter Kreis) Replay hat einen Zug aufgezeichnet und ist bereit zum Abspielen • Play-Symbol (ein gefülltes rotes Dreieck) Replay wird abgespielt Während der Wiedergabe werden die Wörter "Replay" und "aktiviert" in großen gelben Zeichen auf beiden Mainscreens angezeigt. Zusätzlich wird eine Balken-Anzeige für die Einstellung der Replay-Wärme eingeblendet. Replay-Modus benutzen: Der Replay-Modus ist für jedes Profil einzeln änderbar. Es kann direkt in diesem Theme aktiviert werden, wenn diese Funktion in der "Replay"-Screen ("Menu 1" - "Replay") aktiviert wird. Auch kann die Aktivierung des Replay-Modus in den Profil-Einstellungen im EScribe-Programm erfolgen und dann die geänderten Profil-Einstellungen auf das Gerät hochgeladen werden. Wenn der Replay-Modus aktiviert ist, wechselt das graue Standard-Replay-Symbol auf beiden Main-Pages dieses Themes in ein "Stop" -Symbol (zwei rote stehende Balken - ähnlich dem "Pause" -Button auf einem Cassetten-Recorder) . Aufnahme eines Zugs für Replay: Wenn der Replay-Modus aktiviert ist, müssen Sie einige Male dampfen, um den Replay-Modus zu initialisieren. Sobald der Replay-Modus für die Aufnahme eines Zugs vorbereitet ist, wechselt das "Pause"-Symbol auf dem Mainscreen in einen roten gefüllten Kreis (wie der "Aufnahme" -Button auf einem Cassetten-Recorder). Jetzt können Sie das "Aufnahme" -Symbol Anklicken, nachdem Sie einen Zug hatten, der Ihre Erwartungen voll erfüllt. Wiederholen eines aufgezeichneten Zugs in Replay (wird immer wiederholt): Sobald ein Zug aufgezeichnet wird, verwandelt sich das Replay-Symbol in ein rotes Dreieck "Play" -Symbol (auch wie der "Play" -Button auf einem Cassetten-Recorder). Zusätzlich werden die Worte "Replay" und "aktiviert" in großen gelben Zeichen auf beiden Mainscreens des Themes angezeigt. Das zeigt an, dass der vorher aufgezeichnete Zug nun endlos wiederholt wird. Beenden/Unterbrechen des Replay-Modus: Um den Replay-Loop zu beenden, klicken Sie einfach erneut auf das rote "Play" -Symbol. Der gelbe "Replay"-Name verschwindet von den Mainscreens und das Replay-Symbol wechselt zurück in den rot gefüllten Kreis "Aufnahme"-Symbol. Das Gerät ist jetzt wieder in den normalen Benutzungsmodus zurückgekehrt. Durch erneutes Anklicken des "Aufnahme"-Symbols wird der letzte Zug gespeichert und der Replay-Modus wechselt in den Play-Modus. Alle anderen Elemente sollten selbsterklärend sein. ---------------------------------------------------------------------- REPLAY ---------------------------------------------------------------------- VORSICHT! Aktivieren Sie in den Profil-Einstellungen Ihres EScribe-Programms nie die Checkbox "Puff saved, playing". Kontrollieren Sie diese Einstellung, wenn Replay nicht wie erwartet funktioniert. Wenn Sie an dieser Stelle die Checkboxen "Puff saved, playing" aktivieren, wird der Replay-Modus aktiviert - allerdings ohne einen aufgezeichneten Lieblings-Puff, was zu Fehlfunktionen führen kann. Aktivieren Sie also einfach nur die Kontrollkästchen "Use replay on this profile". ---------------------------------------------------------------------- Entwickler Informationen ---------------------------------------------------------------------- Verwendete Toggles: Toggle 1: Volt / Watt - Anzeige in Main 2 (Auswählbar in Screen "Anzeige") Toggle 2: Ampere / Ohm - Anzeige in Main 2 (Auswählbar in Screen "Anzeige") Toggle 3: Zug / Züge - Anzeige in Main 2 (Auswählbar in Screen "Anzeige") Toggle 4: Akku Digital / Balken - Anzeige in Main 1 und 2 (Auswählbar in Screen "Anzeige") Toggle 5: Mainscreen 1 oder 2 - temporär oder statisch - (Auswählbar in Screen "Menu1") Toggle 6: Coil / Vorheiz-Werte - entweder Coil-Temperatur und Coil-Power oder Vorheiz-Temperatur und Vorheiz-Power - Anzeige in den Mainscreens "Mad Eye Moody" und "Hawkeye Pierce" (Auswählbar im TC-Modus in beiden Mainscreens durch Umschalten des Blitz-Symbols) Toggle 7: Uhr ja/nein - Anzeige in Main 2 (Auswählbar in Screen "System") Toggle 8: Zeit / Zeit und Datum - Anzeige in Main 2 (Auswählbar in Screen "System") ---------------------------------------------------------------------- Neu in dieser Version ---------------------------------------------------------------------- 3.1.6 Anzeigefehler im Watt-Mode behoben - Akku-Leer-Anzeige wurde nicht korrekt angezeigt. ---------------------------------------------------------------------- Attachments/Anlagen ---------------------------------------------------------------------- Lockscreen-Pictures.zip Mr. Theo Bottomfeeder LED V2 Manual English German.txt Mr. Theo Bottomfeeder LED V2 Manual English German.doc- 3 comments
- 5 reviews
- 4
- up to 4 batteries
- powerbank
(and 1 more)
Tagged with:
Das kann wohl der Grund sein.😉 -
Danke Dir - Na, dann bin ich ja beruhigt, ich dachte schon, das ist ein Designfehler im Board (OK, kann es ja trotzdem sein - aber wenn's alle wissen, sind die User ja dann darauf gefasst). -
Ist es bei Deinen Themes auch so, dass der DNA beim TC(EDIT KORREKTUR: Temp-Protect meine ich natürlich) an-/ausschalten eine Gedenkminute einlegt, wie ein oller Diesel? Nur dieses Umschalten dauert bei mir ca. 5sec. bis die Anzeige entsprechend aktualisiert wird. Alle anderen Schaltvorgänge gehen ratzfatz. Hier die hoffentlich finale Versionen: Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - German for DNA 75C DNA 250C.ecigtheme Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - English for DNA 75C DNA 250C.ecigtheme Mr. Theo Bottomfeeder LED V2.txt -
EDIT: Nein nein, ich steuere den "New Coil" nicht manuell an. Dafür habe ich den "Coil"-Screen mit fast denselben Inhalten. Mir ging es eben nur um den Rücksprung nach dem automatischen Systemaufruf bei größerer Widerstandsveränderung. -
Hi Gwynar, Ich möchte annehmen, dass "No Old Coil" und "Abbrechen" exakt denselben Rücksprung veranlassen und der "Abbrechen" nur für die eingebaut wurde, die explizit nach einer "Verwerfen"-Funktion suchen und die Möglichkeit die "No Old Coil" dafür zu nutzen nicht überreissen. Oben habe ich im "New Coil"-Screen ohnehin die üblichen "Ja" und "Nein"-Schaltflächen. Nur, um das Bild mit den anderen Screens stimmig zu halten will ich eben auch unten die Rücksprungtaste haben. Prinzipiell stellen die "Yes, New Coil" und die "No Old Coil"-Funktionen m.E. ohnehin intern das übliche "OK" und "Cancel" dar. Aber ich behalte es im Auge - wenn es mit der "No, Old Coil" Probleme gibt, verwende ich die "Abbrechen"-Funktion. Ich denke, man darf diesem Screen halt weder mit "Goto another Screen" noch mit "Goto parent Screen" arbeiten. -
P.S. Ich habe jetzt einfach die Rücksprung-Schaltfläche zum Mainscreen mit "Yes, New Coil" und die Verwerfen-Funktion mit "No, Old Coil" belegt. So umschiffe ich die Frage, ob das "New Coil"-Screen nun intern mit "Goto" oder "Gosub" aufgerufen wird.😉 -
Hi Gwyar, jo, danke. Aber mir geht es eben darum, warum ich bei meinem Theme immer noch ab und an den "Menu Error" bekomme, obwohl ich zwischenzeitlich nur noch mit "Goto another Screen" und nicht mehr mit "Goto Child Screen" und "Goto parent Screen" arbeite. Und daher interessiert es mich, ob beim "New Coil"-Screen wirklich ein "Goto Parent" hingehört, oder nicht vielleicht doch ein "Goto another Screen: Mainwindow". Beste Grüße -
Hello Zark, For me it is also not easy to understand the content of your messages by translating them with a converter.😉 I know, that "New Coil" is a System-Call. My question is how the system opens this screen - since this is important for the correct building of the "Return"-Button. Either it must be declared as "Goto another Screen: Mainscreen" or "Goto parent screen". I think "Goto parent screen" is the correct order, but I am not sure about. I have a very kind friend in this forum who test each version of my theme, searching bugs and other problems and he also has given me a lot of valuable hints for improve this theme more. Also he has corrected the english language part of the manual. My destination is to create a easy and very useful theme with a lot of informations for the users and containing functions that no other theme has build in. If you like, you may test the latest version now. I hope, it is as error-free now as the DNA-coding allows. Kind regards Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - English for DNA 75C DNA 250C.ecigtheme Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - German for DNA 75C DNA 250C.ecigtheme Mr. Theo Bottomfeeder LED V2.txt -
Hello Zark, The "last theme", I've spoken about and what has much more Screens and is more complicated is this one: Mr. TheoBottomfeeder Black English/German/Deutsch for DNA 75C/250C - Replay - PowerBank - up to 4 Batterys But that is another Theme than this one, we're talking about jet: Mr. TheoBottomfeeder LED - Easy Colors For this Theme I build an update in this time. But also in this thread you can see the complete oppositely meanings. You prefer Symbols, and the user Gwyar declines symbols and prefers text-information instead. You see, as programmer, you are never able to fulfill everybody wishes. We'll see, how the users can handle my theme. I need the possibility to let the user select write-protected symbols, since the status-text what describes the meaning of the symbol and it's is-state. Uh, for me it is not really important if and how many times users are using my theme - but what is necessary to me, my themes have to be error-free. Kind regards P.S. A question I have: Do you know, how the system is calling and displaying the "New coil"-screen? Is this by performing a "Goto child" (with needed "Goto Parent" in "New Coil"-Screen) - so Gosub-Return with using the child-stack? Or is this a regular "Goto another Screen", where I need a "Goto another Screen" also in the "New Coil"-Screen - so Goto-Goto without using a stack? This question, because I want to avoid each Stack-Problem. Mr. Theo Bottomfeeder LED V2.txt Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - English for DNA 75C DNA 250C.ecigtheme -
Original theme for therion dna 75c
Mr.Bottomfeeder replied to matteo's topic in Themes and Custom Screens
Hi, I have this found in my achieve. If still needed by someone. Greetings Original Black Theo Gebraucht.ecig Original Black Theo Italien.ecig Original Silber Theo.ecig -
Btw:😉 ---------------------------------------------------------------------- Manual ---------------------------------------------------------------------- ++ Mainscreen 1 "Mad Eye Moody" (bigger chars but fewer information) - Icon: Mad-Eye-Moodys Eye and Mainscreen 2 "Eagle Eye" (smaller chars but more information) - Icon: Eagle-Head: ++ Upper side: Voltage-Value >>clicking opens Screen "USB", if connected - otherwise opens screen "Pack"<< or Upper side: Pack-Level as graphic bar display >>clicking opens Screen "USB", if connected - otherwise opens screen "Pack"<< --Selecting what to show: By clicking the button "Bar" or "Digital" in the screen "Display" - Selected status will be showed-- Voltage-state is displayed in different colors - depending on the battery level (green> = 66%, yellow> = 33% and <66%, red <33%). Charged full and Pack-Empty-Alert when using is displayed in relevant Screens ++Only in Mainscreen 2 "Eagle Eye"++: Below Pack-Display: - Profile and Mode >>clicking one to select a Profile or Mode<< - Date and Time >>clicking one opens Screen "System"<< - Big Time >>clicking opens Screen "System"<< --Selecting what to show: By de-/activating the two buttons "In Main" in the screen "System" - Left button = switching Profile and Mode (red) or time display (green), right button = if time display is activated switching between date and time (blue) or big time (yellow)-- **If firing, a flame symbol appears instead at this place** ++Only in Mainscreen 2 "Eagle Eye"++: Above the lower information line: Left display: "Volt/Watt" - Coil voltage/coil power Right display: "Ampere/Ohm" - Coil current/Coil Resistant Lower display: "Puff/Puffs" - duration of the current Puff / total number of Puffs since reset --The contents for output values for the lower three fields can be chosen in Screen "Display" - the chosen status will be displayed-- ---------------------------------------------------------------------- Symbols (Mainscreen 1 "Mad Eye Moody" and Mainscreen 2 "Eagle Eye"): ---------------------------------------------------------------------- "Thermometer" with two modes 1. In Power-Mode Picture (Thermometer) - Thermometer greyed out >> Clicking opens the "Coil" screen << 2. In TC-Mode - regularly: Switch (Thermometer) Temp-Protect On/Off - Thermometer, if Temp-Protect is switched on and works >> Clicking turns Temp-Protect off << - Crossed out thermometer if Temp-Protect is switched off >> Clicking turns Temp-Protect on << 3. In TC-Mode - Special: Picture (Char) - Crossed out "D" if coil without Temp Sensing Detect (coil with contact problem - fluctuating coil resistance) >> Clicking opens the "Coil" screen << - Crossed out "M" if coil without Temp Sensing Material (wrong coil wire for selected temp control profile) >> Clicking opens the "Coil" screen << "Flash" with two modes 1. In Power-Mode Switch (gray or yellow flash) is displayed to switch Boost on and off >> Switch Boost On/Off by clicking the flash symbol << - Gray flash is displayed, then Boost is deactivated - Yellow flash is displayed, then Boost is activated 2. In TC-Mode Switch (red or green flash) is displayed for switching Preheat-Display-Values >> Switch Preheat-Display-Values by clicking the flash symbol << - Red flash: Preheat deactivated: Display shows - Top: Coil Temperature - Bottom: Preheat Temperature - Green flash: Preheat activated: Display shows - Top: Preheat power - Bottom: Punch Level "Flame / Snowflake" with two modes 1. In Power Mode Picture (Flame) - Gray Flame when Power Mode is activated >> Clicking opens the "Profile" screen << 2. In TC mode Switch (Flame / Snowflake) is displayed for switching Preheat On/Off >> Switch Preheat On/Off by clicking the flash symbol << - Colored Flame if Preheat is activated - Snowflake if Preheat is deactivated "Coil" with two modes >> Clicking opens the "Profile" screen << 1. In Power Mode Picture (Coil) - Grayed-Out Coil with both pins down: 2. In TC-Mode Picture (Coil) - Red Coil with both pins down: Temp-Sense-Material and Temp-Sense-Detect recognized (fully functioning TC-Mode, TC wire with activated Temp-Control) - Red Coil with left pin up: No Temp-Sense-Material, but Temp-Sense-Detect detected (usually should never actually happen - but what is usual 🙂 ) - Red Coil with right pin up: Temp-Sense-Material, but no Temp-Sense-Detect detected (Coil with contact problem - fluctuating coil resistance) - Red Coil with both pins up: Neither Temp-Sense-Material nor Temp-Sense-Detect detected (no resistance wire selected for TC-Mode) Replay: Bottom Center: "Replay"-Buttons (like on a Cassette-Recorder). - Grey: Replay is deactivated - Halt-Symbol (two red vertical bars): Replay is on but not initialized jet (no puff recorded) - Record-Symbol (a filled red circle): Replay has recorded a puff and is ready for playing - Play-Symbol (a filled red triangle): Replay is playing When Replay is Playing, the words "Replay" and "active" are displayed in big yellow chars in both Mainscreens. Additional a graphic bar display for control Replay warmth is shown. Mainscreen 1 "Mad Eye Moody" und Mainscreen 2 "Eagle Eye": Icon below right - Lockscreen (Icon "Bed") or "Mad Eye Moodys Eye") or "Eagle Head" Function: - Icon: "Mad Eye Moodys Eye" or "Eagle Head". Switches in all Screens expect in the Lockscreen and active Mainscreen to the active Mainscreen **Due to the limitation of the software, the Mainscreen 2 "Mad Eye Moody" will always be displayed after unlocking the device, even if Mainscreen 1 "Eagle Eye" is activated as Mainscreen. In these case, the Mainscreen 1 "Eagle Eye" can be accessed again by simply clicking on the lower right icon.** -- Temporary or static specify which screen is defined as Mainscreen by de-/activating the buttons for "Mainscreen" in the screen "Menu 1" -- - Icon "Bed": Switches in activen Mainscreen into the Lockscreen ++Only in Mainscreen 1 "Mad Eye Moody"++: While firing, a flame symbol appears instead of the lower six Symbols at this place All other elements should be self-explanatory. --------------------------------------------- I hope, that's not too difficult for understanding - but a logical way for using the theme.😁 -
Hi Zark, thanks for your comment. I afraid, you have misunderstood something in my theme.😉 Therefor I have published my theme with a short using-manual. TSD and TSM only displays their status as information for the user to figuring out the reason, if his mod won't steam as expexted. There is nothing to set or choose with TSD and TSM - only for displaying and recognizing problems. As well as the PWR- and TC-"LED"s in the Coil-Screen. There you also can't choose one of these modes. It's just as information. In my opinion, my theme is very useable. But sure, it is more complex than probably most others. In Profile-Page, you can set same like in the Escribe-Profile screen but only that parameters, what are allowed with the settings, you have actual chosen (depending on of TC/Watt, Preheat Yes/No, Replay On/Off). So no irritation about nonfunctional fields and values should come up. Most difference to other themes: My theme contains two choose able Mainscreens - a "Mad Eye Moody"-Mainscreen with bigger chars but content fewer information (for users wearing glasses or not so good eyes) and an "Eagle Eye"-Mainscreen with smaller chars but displaying more information (for users with good eyes). My destination is - one Theme for all wishes. As example, the user may choose either a digital Battery-Display or a Bar-Graph for battery-state and may select other values, that he want to get displayed on the Mainscreen etc. Surely I see this with programmers eyes. But I hope, it is not overloaded and easy in handling after a short time of using and getting knowledge about. This theme already is shrunk in its functions. My first theme had more.😂 How you meant - Do I am really writing English as bad, that I need a home language speaking English translator?😯 Kind regards -
Some Beta-Testers searched
Mr.Bottomfeeder replied to Mr.Bottomfeeder's topic in Themes and Custom Screens
Hi Retird, nice to read you again. Yes, I uploaded unfortunately not the latest version of my english language theme by mistake. Thanks for your help again. Kind regards Here the actual version: Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - English for DNA 75C DNA 250C.ecigtheme -
Your Gauge-Picture probably has no transparent parts, where the Fill-Color can visible across. There is no possibility to change Brightness less than 0 or more than Max. 1. The "New Coil"-Screen is automatic called by the system, if the real resistance is higher or lower than the stored. So you have to build two screens with nearly same content. One as "New Coil Screen" what you don't call by hand from another screen And a second with "Special Use: NO" what you can open from other screens as long as you want 2. For this you have to put two fields onto same place. Field :1 Make a condition "hidden" and a second condition "Control: Field - Compare: Atomizer - Power - Comparison: Greater or Equal to - Value: 30W" Source: Coil Power Options: Decimal Places: 0 - Step Size: 1 Field :1 Make a condition "hidden" and a second condition "Control: Field - Compare: Atomizer - Power - Comparison: less than - Value: 30W" Source: Coil Power Options: Decimal Places: 1 - Step Size: 1 By using hidden-Conditions, you can put both fields onto same place and in each field, you have another in-/decrasing of the content Field 1 switches to hidden, if Coil Power < 30W Field2 switches to hidden if Coil Power >= 30W 3. Use the "Statistic - Last Puff - Time" - that shows the Time of your last puff, as the name says. This all is stuff, you can find out by try and error usually.😉 Kind regards
Hi, You have in Theme Designer four available options: Normal: Belongs only Label-Fields and Memo-Fields Text-Color: Visible in all text-Fields what have no self-defined text-color Fill-Color: Visible in all Text-Fields Highlight Read-Only: Belongs Fields, Gauge, Toogle, Picture, Chart and Status ("Status" is unchangeable "Read Only") what have no changeable Value in it's "Source" - "Options" - "Settings" or are marked as "Read Only". Fields Text-Color: Visible in all Read-Only Fields what have no self-defined text-color Fill-Color: Visible in all Read-Only Fields Gauge, Toogle, Picture and Chart: Text-Color: Not availiable Fill-Color: Must be transparent at all places where the Fill-Color should be visible across. Highlight Selectable: Belongs Fields, Gauge, Toogle, Picture and Chart what have a changeable Value in it's "Source" - "Options" - "Settings" - and onto that the (invisible) "Pointer" is placed. Fields Text-Color: Visible in all Fields what have no self-defined text-color Fill-Color: Visible in all Fields Gauge, Toogle, Picture and Chart: Text-Color: Not availiable Fill-Color: Must be transparent at all places where the Fill-Color should be visible across Selected: Belongs Fields, Gauge, Toogle, Picture and Chart what have a changeable Value in it's "Source" - "Options" - "Settings" - and onto that the (invisible) "Pointer" is placed and the Object is clicked with the middle Button to be active. Fields Text-Color: Visible in all Fields what have no self-defined text-color Fill-Color: Visible in all Fields Gauge, Toogle, Picture and Chart: Text-Color: Not availiable Fill-Color: Must be transparent at all places where the Fill-Color should be visible across Error: Belongs the Text-Color of the Full Sized Error-Page Hoping that's matching - otherwise please correct Kind regards
Hi Gwyar, Nun ja, ich habe nichts gegen Anleitungen. Aber wie Du so richtig geschrieben hast, da gibt es verschiedene Ansiuchten dazu. Die Anleitung ist zwar rel. umfangreich, dafür ist diese aber auch in Englisch und Deutsch und umfasst auch allgemeine Infos. Die reine Theme Anleitung ist nicht viel zum lesen. Zumal ich auch bei meinem Theme davon ausgehe, dass es eigentlich selbsterklärend ist. Aber da ich schon beruflich immer Anleitungen mit meinen Produkten ausliefere, ist es für mich selbstverständlich, dass ich es auch hier mache. Beste Grüsse Hi Gwyar, Well, I have nothing against instructions. But as you have written correctly, there are different approaches. The instructions seems voluminous, but it is written in English and German and also includes general information. The pure theme guide is not really much to read. Especially since I also assume with my theme that it is actually self-explanatory. But since I have always delivered instructions with my business-products, it goes without saying that I also do it here. Best regards Wer Lust hat, die neuesten Betas (Englisch und Deutsch) zu testen, hier geht es zum Download: If you want to test the latest betas (English and German), click here to download: -
Hello @all I have completely overworked my latest Theme now: "Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - for DNA 75C DNA 250C" Availiable in English and German GUI-Languages. Before uploading this as final V2.0.0 into the "Download"-Section, I am looking for some Beta-Testers who like to test my Theme and gimme a message, if everything works as expected (or not) - if and how I can make it better. You'll know - a programmer can't find his own bugs and errors. That seems to be in the nature of the human. Therefor it would be kind, if some spend a little time and verify my Theme and it's functions. Any answer is welcome.😁 The Manual for using the Theme you'll find in the attached TXT-File Kind regards --------------------- Hallo an Alle Ich habe mein aktuelles Theme jetzt komplett überarbeitet: "Mr. Theo Bottomfeeder LED - Einfache Farben - V2.0.0 - für DNA 75C DNA 250C" Verfügbar in englischer und deutscher GUI-Sprache. Bevor ich dieses Theme als finale V2.0.0 in die "Download"-Sektion hochlade, suche ich nach Beta-Testern, die Lust haben, mein Theme zu testen und mir Bescheid geben, ob alles wie erwartet funktioniert - ob und wie ich das Theme verbessern kann. Ihr werdet wissen - ein Programmierer kann seine eigenen Bugs und Fehler nie finden. Das scheint in der Natur des Menschen zu liegen. Daher wäre es nett, wenn sich ein paar Members ein wenig Zeit nehmen, um mein Theme sowie seine Funktionen zu überprüfen. Jede Antwort ist willkommen.😁 Das Handbuch zur Verwendung des Themas findet Ihr in der angehängten TXT-Datei Beste Grüße Mr. Theo Bottomfeeder LED V2.txt Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - English for DNA 75C DNA 250C.ecigtheme Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - German for DNA 75C DNA 250C.ecigtheme
Temp Sensing Detect...
Mr.Bottomfeeder replied to Mr.Bottomfeeder's topic in EScribe, Software and Firmware
@all Well, I (hope to) have finished the German version of my Theme now: "Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - German for DNA 75C DNA 250C" Since it is nearly a complete new build theme, I have made it as a major version update. I am looking for some members who would like to test this Theme before I also create the version translated into English. I would be happy if there were a few users who would do this work and inform me about problems / questions / suggestions for improvement. Feel free to get such one.😁 The manual for using this theme, you'll find in the attached TXT-File. Kind regards @all Ich habe jetzt die deutsche Version meines Themes fertig gestellt(hoffe ich zumindest): "Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - German for DNA 75C DNA 250C" Da es sich fast um ein vollständiges neues Build des Themes handelt, habe ich es als Hauptversions-Update deklariert. Ich suche einige Mitglieder, die dieses Thema testen möchten, bevor ich auch die in die englische Sprache übersetzte Version erstelle. Ich würde mich freuen, wenn sich ein paar User finden, die diese Arbeit übernehmen und mich über Probleme/Fragen/Vorschläge zur Verbesserung informieren.😁 Die Anleitung zur Bedienung dieses Themes findet Ihr in der angefügten Text-Datei. Beste Grüße Mr. Theo Bottomfeeder LED V2.txt Mr. Theo Bottomfeeder LED - Easy Colors - V2.0.0 - Beta - German for DNA 75C DNA 250C.ecigtheme -
Hi Zark, thanks again for your answer. Now I understand, what you meant with "TCR" - I thought all the time, that this must be a Russian translating of "TSD" or "TSM" But I am afraid, you're misunderstanding my motivations. I surely don't use the DNA in a manner, what is not provided by Evolv. My destination is to give the users only the information and settable parameters on the screens, what are matching the mode that he actually is using (means in certain circumstances, what he must not have selected manually, but what he is using in fact). And this is including, that the "Power-Mode" not only should be shown and be adjustable in a manually chosen "Power-Mode", but as well in "TC-Mode" temporary as long as TSM= false or TSD=false. Cause under this conditions then the DNA only works in "Power-Mode" anymore, as I believe to have figured it out. TSM and TSD are System-Flags what are set by the DNA and the user surely can't change by himself. But the values of these flags influences the working structure of the DNA. Independently of the users choice "Can Preheat" (="TC-Mode"): If TSM= false or TSD = false, the DNA switch intern to "Power mode" temporary and no temp-control works anymore in that case as long as one of these flags is false. In my opinion, the most themes usually don't inform the user about this fact and as well about the reason for the DNA for falling back into "Power-Mode" nevertheless the user has chosen "TC-Mode" and is getting displayed falsely this mode-settings. If "TC-Mode" was selected before, the DNA only switch back to working "TC-Mode", if TSM = true and TSM=true again. It seems to me, for the user it is same result as if he is choosing "Can Boost" (Power-Mode) manually, if TSM= false or TSD=false. As far my viewings and experiences. So my new version of my theme shows the "Power-Mode"-Mainscreen and "Power-Mode"-Profile-Setting-page, if TSM=false or TSD=false as well as the user has selected "TC-Mode". As soon as TSM=true and TSD=true again, the Screens switches into "TC-Mode" usability back again, if this was chosen before. I hope, this time I could explain understandable, what I have meant.😉 Kind regards Hallo Zark, Nochmals vielen Dank für Deine Antwort. Jetzt verstehe ich, was Du mit "TCR" gemeint hast- ich dachte die ganze Zeit, dass dies eine russische Übersetzung von "TSD" oder "TSM" sein muss. Aber ich fürchte, Du verstehst meine Beweggründe falsch. Ich benutze die DNA sicherlich nicht auf eine Art und Weise, die Evolv nicht zur Verfügung stellt. Mein Ziel ist es, den Benutzern nur die Informationen und einstellbaren Parameter auf den Bildschirmen mitzuteilen, welche mit dem tatsächlich verwendeten Modus übereinstimmen (bedeutet unter bestimmten Umständen, was der User nicht manuell ausgewählt haben muss - sondern das, was der DNA tatsächlich aktuell verwendet). Dazu gehört, dass der "Power-Mode" nicht nur in einem manuell gewählten "Power-Mode" angezeigt und eingestellt werden soll, sondern auch temporär in "TC-Mode", solange TSM = false oder TSD = false . Denn unter diesen Bedingungen funktioniert die DNA dann nur noch im "Power-Mode", wie ich glaube, es herausgefunden zu haben. TSM und TSD sind System-Flags, die von dem DNA gesetzt werden und die der Benutzer sicher nicht selbst ändern kann. Die Werte dieser Flags beeinflussen jedoch die Arbeitsstruktur der DNA. Unabhängig von der Benutzerauswahl "Can Preheat" (= "TC-Mode"): Wenn TSM = false oder TSD = false, wechselt die DNA intern temporär in den "Power Mode" und in diesem Fall funktioniert keine Temp-Kontrolle mehr, solange eines dieser Flags false ist. Meiner Meinung nach informieren die meisten Themen den Benutzer normalerweise nicht über diese Tatsache und auch nicht über den Grund, warum die DNA in den "Power-Mode" zurückfällt, obwohl der Benutzer den "TC-Mode" gewählt hat und fälschlicherweise angezeigt wird diese Modus-Einstellungen. Wenn zuvor "TC-Mode" gewählt wurde, wechselt die DNA nur dann wieder in den "TC-Mode", wenn TSM = true und TSM = true ist. Es scheint mir, für den Benutzer ist es das gleiche Ergebnis, als würde er "Can Boost" (Power-Mode) manuell auswählen, wenn TSM = false oder TSD = false. Soweit meine Ansichten und Erfahrungen. Die neue Version meines Themas zeigt also die "Power-Mode" -Mainscreen- und "Power-Mode" -Profileinstellungen-Seite, wenn TSM = false oder TSD = false ist, selbst wenn der Benutzer "TC-Mode" ausgewählt hat. Sobald TSM = true und TSD = true ist, wechselt der Bildschirm wieder in den "TC-Mode", sofern dieser zuvor gewählt wurde. Ich hoffe, diesmal konnte ich nachvollziehbar erklären, was ich gemeint habe.😉 Beste Grüße -
Oh ja, das kenne ich. Das Schöne... Die Entwickler des Theme Designer haben keine Möglichkeit geschaffen, im Theme festzustellen, wie die dort verwendete Bildchen heißen und wo diese jeweils gespeichert sind, noch kann man im Theme Designer deren Abmessungen erkennen. Das macht es besonders lustig, bei einem Neuanfang aus der Masse an fast identischen selbsterstellten Bildern (die sich nur marginal voneinander unterscheiden), jene herauszufinden, welche man tatsächlich verwendet hat. Ich speichere in einem solchen Fall im Theme Designer die verwendeten Bilder in ein neues Verzeichnis, damit ich sicher dieselben beim Neuerstellen wieder habe. Auch mir geht es so - habe jetzt auch bei der kompletten Überarbeitung meines Themes ein paar Sachen gefunden, bei welchen ich mich schon gar nicht mehr erinnern kann, warum ich die so gemacht und eingebaut habe.😂 Oh yes, I know that. The beautyful thing ... The developers of the Theme Designer have neither created a way to determine in the theme how the used pictures are named and where each of them is stored, nor you can see their dimensions in the Theme Designer. This makes it particularly funny to find out which Pictures are actually been used from the mass of almost identical self-created images (which differ only marginally from each other). In such a case, I save all the images used in the Theme Designer in a new folder, so that I surely have them again when I create the theme once again. I feel the same way - have also found a few things in the complete revision of my theme that I can no remember why I did it and by what reason I have installed it. 😂 -
In solchen Fällen ist es manchmal sinnvoller, nochmal ganz von vorne anzufangen 😂 In such cases, it sometimes makes more sense to start all over again 😂 -
Ja, das ist eben das Schöne an programmierbarer Hardware. Daher habe ich auch Smartwatches von Samsung - weil ich dafür eigene Watchfaces bauen konnte. Nun, ich bin der Ansicht, dass mit Pictogrammen mehr ausgesagt und auf einen Blick erfassbar ist, als mit einer Textausgabe. Ich habe ja vier Symbole in meinen Main-Screens: 1. Thermometer (TC-Mode) - durchgestrichen (Kein TC-Mode möglich) - grau (Power-Mode) - mit "D" (drin TSD=False) - mit "M" drin (TSM = false) 2. Blitz (Power-Modus: Boost-Parameter-Anzeige Ein/Aus) - im TC-Modus: Preheat-Parameter-Anzeige: Ein/Aus) 3. Flamme (im TC-Modus Preheat: Ein/Aus) - Grau im Power-Modus 4. Spule (Power-Modus: Grau) - im TC-Mode Beide Beinchen unten: TSD= true, TSM = True - Linkes Beinchen in der Luft: TSM=False, TSD=True - Rechtes Beinchen in der Luft: TSM=True, TSD=False - Beide Beinchen nach Oben: TSM=False, TSD=False Und dies eben als Statustext jeweils den vier Pictogrammen zugeordnet. Wenn ich das als "Nur-Text" hätte ausformen müssen, würde ich wohl ein doppelt so grosses Display brauchen. Ach ja - noch ein Symbol in den Mainscreens: Das kleine Vorhängeschloss, wenn Temp-Lock aktiviert ist. Yes, that's the nice thing with programmable hardware. That's why I also have smartwatches from Samsung - because I was able to build my own watch faces for them. Well, I believe that pictograms are more meaningful and understandable at a short view than with text output. I have four symbols in my main screens: 1. Thermometer (TC mode) - crossed out (no TC mode possible) - gray (power mode) - with "D" (inside TSD = False) - with "M" inside (TSM = false) 2. Flash (power mode: boost parameter display on / off) - in TC mode: preheat parameter display: on / off) 3. Flame (in TC mode Preheat: On / Off) - gray in power mode 4. Coil (power mode: gray) - in TC mode both legs below: TSD = true, TSM = True - left leg in the air: TSM = False, TSD = True - right leg in the air: TSM = True , TSD = False - Both legs up: TSM = False, TSD = False And this is assigned to the four pictograms as status text. If I had to write this all as "plain text", I would probably need a display that is twice as big. Oh yes - another symbol in the main screens: The small padlock when Temp-Lock is activated. -
Da habe ich Symbole in den Mainscreens, die den Status von TSD und TSM anzeigen. Wenn im TC-Mode plötzlich die Watt-Screen angezeigt wird und im Symbol der Wicklung plötzlich ein Beinchen in der Luft hängt, dann weiss der User, dass er nach dem Coil sehen muss. Zumal in der Statusleiste dann steht, was das Problem ist. So habe ich das nun gelöst. Therefor I have a wire-symbol in the main screens what shows the status of TSD and TSM. If the watt screen is suddenly displayed in TC mode and suddenly a leg is hanging in the air in the wire-symbol of the winding, then the user knows that he has to take a look onto the coil. Additional the status bar shows what the problem is. So I've solved that now.
