masonjarvapes
Everything posted by masonjarvapes
  1. I'm placing the screen elsewhere(not right in front of the board) can I use silicon(liquid firming type) so that the board is spaced correctly away from the metal box and also electrically isolated from the box as well?
  2. What kind of ribbon cable is it specifically? How many pins?
  3. I'd rather not if there is a prebuilt extension
  4. I believe it's been asked before but with no answer...is there a prebuilt ribbon cable extension for the display?
  5. In theory wiring up multiple 510 should be fine as long as they are parallel and do not exceed the maximum ohms allowed correct?
  6. Can you just clip them off Instead of desolder?
  7. I'd rather not have the buttons on the board for accidental pushes if something shifts around
  8. What'd you use for internals and power supply
  9. So as far as we know there is no prebuilt extension ribbon for the screen?
  10. I have something special in mind, my question to DNA is can I order one without the switches installed?
  11. maybe this has been covered but i noticed that you can wire up remote buttons for the fire, + and -. If you use those, do you have to remove the buttons already on the pcb or will it still work?
