            lalemandrew
                Posts50
Everything posted by lalemandrew
	Thanks figured so but don't wanna screw up and how can I wire white connection to go out back of board instead of screen side
	Where the battery goes into the board can I wire 2 wires with the orange adapter so I can swap batteries and make easier external charging
	Thanks everyone I'll post results later
	So I wired everything up with xt60 worked like a charm so now it's time to put in box so I find out it won't fit with the battery connectors so I cut them off and wire directly to the board finish everything now it Wont turn on I'm so frustrated I have been doing this for 4 months and have over $200 invested so what could be going on any help would help thanks and pray for me lol
	What if I have a 2200 with 25c is that ok
	How do I know if the battery will work I know it has to be a Lipo 3s 11.1v but what else is important
	WHat A is the battery supposed to supply to boarx
	What's a better brand
	So this battery is good
	What does the discharge need to be on a battery to properly run the DNA 200 board and how do I figure out a battery discharge rate? Will this work
	  momentary switchlalemandrew replied to lalemandrew's topic in Connectors, Components, and Accessories How can I wire a momentary switch with an led light in it to only light when hitting button I seen it done where u run it from the 510 but I'm worried if I'm vaping 100w I'm technically not cuz I'm drawing power for led does anyone know what to do and is there a good video?
	So I can run the ground to the 510 connector off the board
	Then for the ground do I have to run wire from there to side of box or something
	Do u have a picture of what the board looks like soldered on
	How about power to board
	How do I hook the battery up to board besides the jst-hx thanks guys I'm such a noob and terrified
	How do I install a jst-xh connector on my battery I have the standard 2 hole connector on my zippy battery
	What size wire should I buy and what typeof soldering iron and size solder thanks everyone
	On the shapeways faceplate can I remove pre installed buttons and add metal buttons to the board I want a metal fire button and up downclickers and will it mount on faceplate ok
	  What battery are you using/planning to use?lalemandrew replied to vaporlips's topic in Batteries and Charging
	  What battery are you using/planning to use?lalemandrew replied to vaporlips's topic in Batteries and Charging What gauge wire did you use
	I was planning on building a simple DNA200 mod just like the swirl paint DNA40 video on YouTube and having a tinted magnetic door on my box but I don't want usb to be on the tinted glass I want it on the side is there anyway possible to do so and I can't use an extension because thechip will be up against the glass thanks
