nicovape
Everything posted by nicovape
It works flawlessly since
Well, i went the vodka way. One shot for DNA and one Shot for me The vodka came out pretty dirty and oily. the button works fine so far hopefully, this will be final Photo for fun
Thanks mate! one shot for DNA and one shot for me
i thought of using denatured alcohol that is used to clean wounding and so on.. that's all i have here.. well besides vodka, and other stuff of course.. but not sure that would be good either.. so basically i should do nothing at this point. so far it is still working after a few hours.. but i'd rather clean it properly, as this autofiring that happened without me noticing was a little scary
I could give it a shot. i did not dare to fill a glass up to the point where the button is immersed. but that should be rather safe. Nobody has objection on this idea?
of course it is a typo. air spray! I will edit my post haha. I am not retarded. I think the button got juice over the past few months and it is not so good apparently. i want to clean the button, but i don't know how to access it to clean
The ribbon cable is not on the way of the button. I already fixed this long ago. now, i opened it again, and cleaned with air spray, and other things.. the button is back to life, but for how long? I don't know how to open the front cover, to access the button. Do you know of any video or instruction to do it safely? I already ordered another reuleaux, this one is dying on me, and i love this mod. So i will get another one and this will be a guinea pig. The funny thing is my hanna modz V200 from August last year, is still alive and rocking, even if it is supposed not to be solid. but the battery life is just awful.
Ok after one hours of flawless work.. it autofired.. I did not pay attention when i stopped vaping, it fired long.. and keep firing all the time now.. the button feels funky. I think, i am going to throw this mod by the window
I might have fixed it. Since it worked fine from Device Monitor "puff" feature, i supposed it could be more of a "mechanical" issue, in the sense of contactors.. So i used some electronic cleaning spray. Which is used to remove oxydation and clean contactors. I flooded it and pressed the button one hundred time. did it a few times. now, it seems to work again correctly. I don't want to scream victory yet, but it could be that liquid from some drippers leaked on the button (100% VG FTW) and it did not work so good anymore. I used it for many months now. Early november. If that fixes it, it is a good thing to know..
Works perfectly well with the "puff" feature in the device monitor..
Good idea, i will experiment there
It seems that if i set it to 7X to lock, it doesn't happen.. But, i counted, and if i want to lock or unlock, it will do it on 5X , not 7X.. Is there a bug in the locking feature, or is my mod/board going fubar
Hello everyone! I have a strange issue on my Reuleaux DNA 200. Sometimes, i am vaping and it says lock, even though, i did not lock it. Sometimes it says locked. but will fire again on the next try! just one press and it will fire even though, it said locked on last try. Then show locked, then fire again.. sometimes it is very hard to unlock.. This is driving me crazy.. Anyone experienced such problems before ? I set it to lock on 3X, which used to work very well. I tried both recommended and last firmware.. same..
Escribe upload settings to device error
nicovape replied to firstdna200's topic in EScribe, Software and Firmware
Yes, using 2/29 and i sent you a PM. -
Scy123! I am very glad it helped ! I hope Administrator will notice this post. I had noticed one thing, before i changed the settings to manual english, one profile tab (only one), had no possibility to select a custom picture. that feature was not showing up at all in Escribe. Maybe that resulted in a corrupted setting file that were trying to be sent to the mod. When i changed to english, all my profiles tabs were back to normal and i could upload settings -
Ok, i found a way around my problem, maybe it will be interesting for you James. Escribe was set to Autodetect and i am French. So it was using French as auto detected. I thought about what was written earlier in this thread, and I manually changed the language to English. And i tried to upload settings. Guess what? It worked! So for some reason, the french auto detect was giving me this curve error, while the english setting does not. -
I have the same problem, i can't change any setting from the mod anymore via escribe. I can't download fine, but i can't upload anything. even a simple download and upload will fail with the "Curve is not one to one". always get this error.. Is there a fix for this ? This is driving me nuts.. -
Feature request - SCROLL SPEED!
nicovape replied to p8ntballa9362's topic in EScribe, Software and Firmware
would be good to have 5 or 10 watts increments in the options. Better yet, allow the user to input the increment value. -
I would also prefer to set the temp on the main screen instead of watts. But i suppose this will not be added until a long time.. there are a lot of small changes that would be nice. Such a feature is probably very easy to implement.. which is the sad part. I wonder if any new firmware / escribe is going to be released soon.. Been a while.
Feature Request, power off function
nicovape replied to postfixx's topic in EScribe, Software and Firmware
you can already lock the device and after 1 hour i think it is, it will go in sleep mode. where it doesn't eat much battery at all. -
Escribe request (not really a bug, but it annoys me)
nicovape replied to nicovape's topic in EScribe, Software and Firmware
alright -
Would it be possible to change Escribe, so it doesn't complain if i change the temperature to Celcius in device monitor (set temperature feature), before i enter a value. It might sounds like nothing for you because you never switch to celcius, but for some reason, i keep changing to celcius before i enter the temperature, and it bugs me to first enter the temperature i want, and then select Celcius. "Value must be a number" I am sure you could check whether the user entered a number whenever he presses "OK", or preset the input field with the current temperature, so it doesn't complain if the user goes in the drop down menu first Very easy to fix.. and I would appreciate it. Thanks Evolv -
How many p/s do you get ? Aircrack was originally written by a friend of mine, also french like me. There are better alternative though. My friend atom, who writes oclhashcat is the best password cracking tool out there. it is not open source, but there is a linux and windows version. That tool support almost everything you can dream of. (hashcat is for cpu only, and oclhashcat is for gpu)
No, i don't but I have a password cracking station (looks like a mining box) with open case near me (work related , i do computer security stuff).. There are 5 gpu , 2 outside of the computer. Maybe that's it. But if i push the pin a little to the center, it gets back to 0. it is like the pin moves against something and then, it shows a resistance. I don't know..
