Thanks so much for posting information about this issue!!!! I did suspect an issue with the 510 and did remove it but nothing stood out so I began to suspect a connection issue to the board. Taking the Paranormal apart is no joy and there are hidden screws under the tape which covers the magnets but I was unable to get the unit apart to gain access to the board. For this reason I avoided buying the Paranormal 250C and have decided to just build my own DNA250C Mod. I am just happy to have my Paranormal 75C working properly.
It takes several hours to run the case thermal test. I am certain that results will vary based on the ambient air conditions but this of course is speculation on my part. For example when I did mine the central AC was so when the HVAC system turned on I would think it may have impacted the results.
Thanks so much for posting this modification. I did the modification. I had to put a set of magnifiers on to see the actual button hitting the screen. I never like taking things apart but after seeing this first hand it would only be a matter of time before the button wore out the ribbon and cause a shorting condition so yea best to just move the ribbon. One has to wonder how many other mods are out having the same issue.
Honestly I can't say that I did. Any difference there might be now I would probably not even notice because I am back to rotating mods where as before I was just vaping on the HCigar VT200 exclusively to see what it would do, how far I could push it so I would better understand its strengths and weaknesses.
I have it set to 14.43. I know some have run the Battery Test and have reported results of 9-11 Wh. I tell you honestly I do not know what is correct and what is not. What I do know is that if I am vaping at like 40-50W during the day only using my VT200 I can get 16 hrs out of it. Sometimes I vape higher wattages about 65-75 although on some occasions I will got over 100 so with mixed wattage settings during the day just using the VT200 I got 13 hours out it. I was happy with the results I got then I resumed vaping multiple mods during the day I always have 2 with me sometimes 3 on my person just to change things up. While I like the VT200 I am more interested in the Reuleaux so once those are available I will get that and the VT200 will still get used but if I want to vape something at really high wattages I do not want to worry about battery life and with the Reuleaux you can easily swap out the 3 18650's and do as you please where as with the VT200 your really limited because lets face it if you vape this thing at 150W or Higher its going to die quickly. Hope this makes sense. I do chain vape and while I can be happy at lower wattages there are times when I want to vape for a period of time at the higher wattages and that's where I worry most with the VT200 battery life.
