pol
    Poland
    Realeaux DNA200
pol's Achievements
  1. pol
    Translations
    Polish tranlation for EScribe: PL_ EScribe Suite 2.0 SP17 v2 - for international customers (Windows) PL_ EScribe_2_0_SP17_v2.zip
  2. pol
    Translations
    Polish tranlation for EScribe: PL_ EScribe Suite 2.0 SP17 v1 - for international customers (Windows) PL_ EScribe_2_0_SP17_v1.zip
  3. pol
    Translations
    @James If you have the opportunity to reveal the correct content of the "msgid", I would be happy. For a file EScribe.po for EScribe 1.2 SP5.2 #. menu->Tools->Production Utility msgid "Automatically Program & Test on USB Connect" #. Mod tab -> button Battery Analyzer ##. popup screen - Battery Analyzer msgid "Attach a resistor capable of sinking the test power you choose." msgid "(40W is a reasonably representative test power.)" #. General tab->Atomizer Analyzer ##. popup screen - Lock Ohms msgid "You should avoid locking Ohms unless your atomizer is extremely unreliable. Never change coils without unlocking." msgid "Continue?" ##. popup screen - Override Ohms msgid "The device's Ohms measurement tends to be quite accuurate, and take connectors, etc. into account.." msgid "Are you sure you want to override Ohms?" msgid "This feature should only be used with temperature-sensing coils." #. Tools->Production Utility -> button Program & Test ##. popup screen - msgid "Test Fire" msgid "Apply" msgid "The EScribe Service Pack is Ready. To apply it, click Apply." msgid "Exiting" msgid "This program is about to exit to apply the Service Pack. Click Cancel if you need to save your work beforehand." For a file all.po for EScribe Suite 2.0 SP15 (For international customers (Windows):) #. popup screen -> Edit... -> Edit Languages msgid "Service Packs always replace the default .po files, so make sure to keep a copy of your edits. A copy of en.po (US English) is a good place to start a new translation form." msgid "Also, you can refresh by selecting your language in the Language menu. Some text may require restarting this program to refresh." msgid "Continue?" #.Diagnostics -> Perform USB Recovery Charging -> USB Recovery Charging -> msgid "This device has had {0} recovery charge(s) performed." msgid "Continue?" #. tab Mod -> Battery -> Type: msgid "Power Supply" msgid "Custom" msgid "Nickel 200" msgid "SS 316" msgid "Titanium 1" msgid "Watts" msgid "NiFethal 30" msgid "SS 430" ##. Evolv DNA 75 #. Theme Designer -> Indicator Light -> msgid "DNA 75 has an indicator light." #. Theme Designer -> Space Used msgid "Off-Board Memory:" msgid "On-Board Memory:" #. Mod tab -> button Battery Analyzer ##. popup screen - Battery Analyzer msgid "Attach a resistor capable of sinking the test power you choose." msgid "(40W is a reasonably representative test power.)" #. Tools->Production Utility -> Program & Test msgid "Fire Test: {0}." msgid "Resistance out of range: {0}Ω." msgid "Didn't fire" #. DNA75Color -> Theme Designer -> tab Screen msgid "Diagnostics" msgid "Puff Info" msgid "System" msgid "About" msgid "Recording" msgid "Patents" msgid "Settings" msgid "Main Profile" msgid "Time Bars:" msgid "Location:" msgid "Size:" #. Evolv DNA 75 color -> General tab msgid "Replay" For a file all.po for ECigStats msgid "·····Connect a compatible e-cigarette to view its ststistics." Thanks! pol PL_EScribe_Translations.zip PL_ECigStats_Language.zip
  4. pol
    Translations
    @James Hi, For a file .po for EScribe Suite 2.0 SP9 (international customers) I need correct records for msgid: #. tab Mod -> Battery -> Type: msgid "Power Supply" #. DNA75Color -> Theme Designer -> tab Screen msgid "Time Bars:" msgid "Location:" msgid "Size:" Thanks! pol
  5. pol
    Translations
    @James Hi, I have a problem with finishing the translation ECigStats. I need correct records for msgid: For a file .po for ECigStats msgid "·····Connect a compatible e-cigarette to view its ststistics." Thanks! pol
  6. pol
    Translations
    It was supposed to be #. DNA 75 Color ->tabs Theme Designer msgid "&Language"
  7. pol
    Translations
    @James Hi, I made changes to the translation text according to your suggestions. However, I have a problem with finishing the translation. I need correct records for msgid: For a file EScribe.po for EScribe 1.2 SP5.2 #. menu->Tools->Production Utility msgid "Automatically Program & Test on USB Connect" #. Mod tab -> button Battery Analyzer ##. popup screen - Battery Analyzer msgid "Attach a resistor capable of sinking the test power you choose.\n(40W is a reasonably representative test power.)" #. General tab->Atomizer Analyzer ##. popup screen - Lock Ohms msgid "You should avoid locking Ohms unless your atomizer is extremely unreliable. Never change coils without unlocking." msgid "Continue?" ##. popup screen - Override Ohms msgid "The device's Ohms measurement tends to be quite accuurate, and take connectors, etc. into account.." msgid "Are you sure you want to override Ohms?" msgid "This feature should only be used with temperature-sensing coils." #. Tools->Production Utility -> button Program & Test ##. popup screen - msgid "Test Fire" msgid "Apply" msgid "The EScribe Service Pack is Ready. To apply it, click Apply." msgid "Exiting" msgid "This program is about to exit to apply the Service Pack. Click Cancel if you need to save your work beforehand." For a file .po for EScribe Suite 2.0 SP9 (international customers) #. popup screen -> Edit... -> Edit Languages msgid "Service Packs always replace the default .po files, so make sure to keep a copy of your edits. A copy of en.po(US English) is a good place to start a new translation form." msgid "Also, you can refresh by selecting your language in the Language menu. Some text may require restarting this program to refresh." msgid "Continue?" #.Diagnostics -> Perform USB Recovery Charging -> USB Recovery Charging -> msgid "This device has had {0} recovery charge(s) performed.\nContinue?" #. Theme Designer -> Indicator Light -> msgid "DNA 75 has an indicator light." #. Theme Designer -> Space Used msgid "Off-Board Memory:" msgid "On-Board Memory:" #. Mod tab -> button Battery Analyzer ##. popup screen - Battery Analyzer msgid "Attach a resistor capable of sinking the test power you choose.\n(40W is a reasonably representative test power.)" #. Tools->Production Utility -> Program & Test msgid "Fire Test: {0}." msgid "Resistance out of range: {0}Ω." msgid "Didn't fire" #. DNA 75 Color ->tabs Theme Designer msgid "@Language" #.DNA 75 Color ->Theme Designer -> tab Screen msgid "Diagnostics" msgid "Puff Info" msgid "System" msgid "About" msgid "Recording" msgid "Patents" msgid "Settings" msgid "Main Profile" Thanks! pol
  8. EScribe 1.2 SP5.2 OS: Windows XP Click Evolv DNA75 Color Error
  9. pol
    Translations
    Polish tranlation for EScribe: PL_ EScribe 1.2 SP3 v1 - PL_EScribe_1_2_SP3_v1.zip (15.81 KB, 34 views) (download link removed) Edit (Oct 06): PL_ EScribe 1.2 SP3 v2PL_EScribe_1_2_SP3_v2.zip
  10. pol
    Translations
    @ RallyRace, Tray as msgid "Failed to connect to the computer at :{0}."
  11. pol
    Translations
    ##. *** 2016-08-08 EScribe 1.2 *** From EScribe 1.0.56 to EScribe 1.2 changed msgid "&Units" msgstr "&units" msgid "&Automatic" msgstr "&automatic" msgid "&Metric" msgstr "&metric" msgid "&English" msgstr "&english" msgid "Share Profiles" msgstr "share profiles" msgid "Automatically Check for Service &Packs" msgstr "automatically check for service &packs" msgid "&Suggest Changes for Potential Mistakes" msgstr "&suggest changes for potential mistakes" msgid "User &Interface" msgstr "user &interface" msgid "&Clean" msgstr "&clean" msgid "&Researcher" msgstr "&researcher" msgid "&Manufacturer" msgstr "&manufacturer" msgid "&Network" msgstr "&network" msgid "&Connect to Remote Computer..." msgstr "&connect to remote computer..." msgid "&Share My Devices..." msgstr "&share my devices..." msgid "&Apply Service Pack..." msgstr "&apply service pack..." msgid "Perform USB Recovery &Charging..." msgstr "perform usb recovery &charging..." msgid "Share Themes" msgstr "share themes" msgid "{0} is available!" msgstr "{0} is available!" msgid "Click here to apply it to your device." msgstr "click here to apply it to your device." msgid "Apply Service Pack" msgstr "apply service pack" msgid "A Service Pack is about to be applied." msgstr "a service pack is about to be applied." ##. Device Monitor msgid "&Issue Serial Command..." msgstr "&issue serial command..." msgid "R&un Script..." msgstr "r&un script..." msgid "Issue Serial Command" msgstr "issue serial command" msgid "Command:" msgstr "command:" #. The default example just changes everything to lowercase. Downloads Polish tranlation for EScribe: Edit (August 08): PL_EScribe 1.2 v1.zip
  12. pol
    Translations
    @ RallyRace, You look
  13. *** 2016-05-06 EScribe 1.0.56 *** from Evolv's site - SetupES75.exe Download EScribe
  14. Evolv DNA75/200 - EScribe
  15. pol
    Translations
    *** 2016-05-06 EScribe 1.0.56 *** From EScribe 1.0.42 to EScribe 1.0.56 changed #. Welcome tab msgid "Welcome" msgstr "welcome" msgid "Connect and Download Settings" msgstr "connect and download settings" msgid "Edit New Settings" msgstr "edit new settings" ##. msgid "Evolv DNA 200" ##. msgstr "Evolv DNA 200" ##. msgid "Evolv DNA 75" ##. msgstr "Evolv DNA 75" msgid "Open Settings from File" msgstr "open settings from file" #. Theme tab /for DNA 75/ msgid "LED" msgstr "led" msgid "Charge Complete:" msgstr "charge complet:" msgid "Normal Operation:" msgstr "normal operation:" #. Screen tab /for DNA 75/ msgid "Temperature-Sensing Coils" msgstr "temperature-sensing coils" msgid "Power-Controlled Coils" msgstr "power-controlled coils" #. Material tab /for DNA 75/ msgid "Temperature-Sensing" msgstr "temperature-sensing" #. Mod tab /for DNA 75/ msgid "This mod uses an external battery charger." msgstr "this mod uses an external battery charger." #. The default example just changes everything to lowercase. Downloads Polish tranlation for EScribe: Edit (May 07): [b]PL_EScribe 1.0.56 v1.zip[/b]
