2legsshrt
Everything posted by 2legsshrt
Why can't someone come up with an SS316L profile
2legsshrt replied to 2legsshrt's topic in DNA 200 and 250
How do you get a screenshot that you can display on this forum or others? -
I've tried Jaquiths V4 V7 the only ones still available the SS316L from SE and the escribes SS316. The V4 is way too hot even at 375F the V7 is too cool the escribes isn't bad at 480+F this one is the most accurate very rarely hits TP seems to work well with the firmware the SE is ok. I can't get Jaquiths V3.5 or 3.25 which I think might be better then the V4. Will try escribes SS304 heard that's not bad but I'm really not impressed with the way this DNA75 works with SS316L. -
I was looking at the curves that were set up on my Therion and on SE. That's where they got the profiles. The standard settings from Escribe are probably set up correctly. This new curve that I found for 316L works very well.
Well I saved the profile from the Escribe SW so I will look at it. Do you think the v1.2SP3 is the better even tho it hasn't been released?
OK maybe I'll give that a try. The one I have now is actually really good at 450F. I take it I can open it and save the profiles as .ecig files and load them onto my device when ever I want. I haven't tried any of the others that came with the Theriion and really the only other wire TC that I use is Ti. I will give it a try. I know when I first opened it it had 4 profiles and this is the latest software for the 75 v1.0.52 or 54 I think. I heard the newest profiles were pretty good but not sure if that is in this version or the beta 1.2SP3
I should have saved the ones that were in Escribe but I didn't and the Lost Vapes ones over wrote those not sure how to get them back.
Both but I am new to DNA's I've used SX's since they first came out and I'm used to that vape. This profile is a little better but still not like an SX with TCR set to .00092 at 420F. I don't have the Escribe setting for SS316 I have the Lost Vapes setting and it is way too low. I've heard the Escribe settings are better but this Therion had 7 or 8 Presets and they are set to SE which I found out that their profiles for SS304 430 316L and NI200 are all the same which makes no sense. I'd like to try the generic Escribe one but not sure how to get that.
Yeah if you don't mind turning it up to 480F
Did a search and someone had a profile from a German site I believe and it works. It's called Stahl316. Do a search on ss316L profiles and you'll find it. Can't believe anyone here can't do a good one.
Hey who ever put that Stahl profile up it works great THANKS
Well I just checked the curve in SE and it is the same for NI200 SS316L SS430 and SS304. So that's no help at all. Is there anyway to just set the TCR on these things. So far I am not impressed at all.
OK i just checked the curve from SE and the one that is included with the Therion and they are exactly the same. Way off. Way too hot and Daniels is way too cool. I have to run it at 460F to get any kind of a decent vape. Maybe I am too used to the SX's running at 420F with the TCR set at .00092
Ok I have watched the training simulator, PB's review on escribe, Djlsb's and I still don't understand some things. I was able to replace the 316L profile that came with my Therion using Daniels which were .ecig files and it works pretty good but the ones from SE which are .csv files I am totally confused about how to get them on the device. Also how can you replace the profiles that came with it with escribes. The manual doesn't explain it and the simulator when I get to a certain point stops picking up my clicks so won't move on.
Well I know I've talked to you before possibly in the wire threads, Ti
Spirometry you are correct. I know for me having used TC since the beginning but with SX's it is real confusing. With the SX you just dial in the TCR easy peasy.
DW I've talked to you around on ECF I'm sure you have some YiHi's correct.
I was kind of hoping this Therion would work with the settings right out of the box but have heard that the SS316L in TC is not good. So the one in 1.0.56 is good?? What is the first thing I should do with my Therion when I pick it up at the PO tomorrow, Connect and download settings then save them to a file say named default then I can mess around with the .csv files and still go back to the default but I have to do each one separately is that correct?
OK since I have a DNA75 I have the right version. But the 1.2SP3 is for all versions but it is sort of beta FW correct?
Well now I am confused because it says the recommended FW is v 1.0.42 I already have 1.0.56 which I am sure is later then .42
What is the latest FW for the DNA75. I am new to the whole Escribe thing. I'm not new to TC but all my experience is with the SX YiHi board. I've been using TC since they first came out with the M class. I use SS316L and Ti almost exclusively. If I have the correct FW will it automatically update my settings for different wire or what. I haven't gotten my mod yet because we have been on vacation for 5 weeks but it is waiting for me at the PO. It is a Therion and has several presets already in it but I have heard that they don't work real well with SS so how do I upgrade them. Thanks I hope I am asking this in the right place. I have v1.0.56
Oh I also should have added that I have Escribe v1.0.56
