2legsshrt
Everything posted by 2legsshrt
Say I was going to ask you do I need to worry aboout any updates I installed the service pack and escribe didn't say anything about installing anything else.
Yep I'd probably be lost using the case analyzer. Something I should find out but it is holding temp now as well as my Triade almost a perfect straight line.
Nope I just put it there to get your attention. Yeah it had under manufacturers settings at the bottom part were either 100 or 0. Steve gave me what he got off of his when he measured it so now it is all up to date there. They had the Kanthal limit at 100 everything was just probably like it came from Evolve. 0 case resistance now set to .004 and all the other numbers set to what he got after measuring.
This is all the info that was available on that screen
Oh and I forgot to say it was not configured at all. I think that was one of the problems. Steve had run the case analyzer and gave me the numbers it just had the boards out of the box numbers in it.
Thanks I'll check that.
Yeah I am really impressed with my Triade. The configuration makes it almost more comfortable in the hand then the Therion or the VT133 but I've heard a lot of good things about the VT133. Don't know if I got one of the earlier ones because I don't know if the serial number is a correct way of knowing it is 0226 which is pretty low. But that is why I decided to get the VT133 because of all the good reviews by fellow users of it and so far it seems like a well built mod not as good as the Therion but close.
OK I will keep an eye on them through the DM and see where they are actually at. 3.3 seems to be fine that is where my YiHi's and other DNA's seem to be when the battery bar is empty. 3.6 is a little on the high side. The bar is actually moving faster then my Lavabox 75 wich is a single battery and I use them at the same setting. They are not even coming close to 30a. I am not a tootle puffer but I am a single coil SS vaper and they are only using about 12w to maintain my temp setting. But all are perfectly holding temp with SS. The line in DM is nearly straight at 410F amazing to me with that wire. Now that I have used all 3 I really like the 133 so I have the new Therion 133 on my radar. I love my Therion 75. The 200 board seems to be steadier at temp then the 75 not a lot but definately a diff.
OK well Maybe I'll let them go this is another brand new set and after I actually vape them down to about 3.3v, since I can check the actual voltage on the DM then maybe I will change it down to 20WH. I was lucky enough to have someone who did the testing to get the case numbers for it and I have soft cell cutoff set to 2.8. Like retird said they take some time to get used to the batteries. When the bar was empty before the batteries were still at 3.6v on my charger.
Does anyone think that 22.2 WH is high for 2 LG HG2 batteries even though they are rated at that they are not a LiPo cell. I can tell that my battery bar is still moving too fast for the batteries or do you think it should be left well enough alone at that and just keep vaping after the battery bar shows empty till I get a low battery warning. I have all the numbers dialed in now on my VT133 for the case and the batteries but like I say I can tell teh battery bar is moving too fast for the way I am using it. I am pretty sure that the batteries are still going to be fairly well charged when the bar shows empty.
Yep your right about waiting but I'm really glad there are people around like Steve to help and giving me all the settings for the mod that he went through the work to get was really nice of him. HCigar didn't put any of the manufacturers settings in like you might already know and it's working better now plus I notice the resistance on my atty went down to where the others showed it. Gotta love these DNA's and all the help that's available.
Well I got some help from another friend in dialing thhis mod in correctly. He gave me all his settings for what should have been put on by the manufacturer and it seems to be working much better. Will update you on the Battery Bar issue.
And I take it I should do a soft reboot
OK so you think it is ok to leave it at LiPo with 22.2WH with 2 18650 LG HG2's in it
I changed my setting in the manufacturers settings for WH from 14.4 to 22.2 still 2 cell LiPo on my VT133. My battery bar showed completey empty and I still had 3.7v in the batteries. I wonder if I should change it back to 14.43 like it was if that would make a difference. Definately not right. I probably should've left well enough alone I guess. Any ideas.
I found some in the UK at this address http://vapegeek.co.uk/searchquick-submit.sc?keywords=replacement+battery+doors+for+therion
Oh and I believe it is in the UK. Haven't seen one in the states.
Check this thread in ECF somewhere in there is the name of a place that sells the battery doors separately. They even have the Ostrich one. https://www.e-cigarette-forum.com/forum/threads/lost-vape-therion-dna75-dual-18650.746027/page-6#post-18213109
From what I have heard the profile for SS316L from Lost Vapes was way off. I did like you and changed that profile as soon as I got it. I used the .csv from Steam Engine which worked well for me. On the Therion thread at ECF so many complained about the profile I didn't even bother with it. But I use SS316L in TC works perfectly.
Listen to him he knows a lot more then me I'm a newbie at this Escribe thing he's not, I just told you what I did and it was a hit or miss process for me. I only use 2 different wires and sometimes will use power so I'm not even sure if I have the original settings and for me I wasn't that impressed with them anyway. The profiles in Escribe were better to me then Lost Vapes and Steam Engines even better in some things. I never thought of doing what he said to do now maybe I should have. Learn something everyday about these things. That's what I mean about asking questions. Like I said there are guys that know a lot more then me so don't try something you are not comfortable doing. Thats the fun part about these you do learn something everyday.
I should say if you are not comfortable doing this don't until you have a better understanding of how Escribe works in conjunction with your Therion. Once you hook your Therion to Escribe it will download all of your stock settings so If you screw up you can always go back to the original configuration just like with a computer when you restore your system to original. Like I say if your not comfortable doing it don't come back here and ask questions, there are a lot of guys here with a lot more experience then me that will help you.
Well I can tell you what I did, it will probably sound confusing but I opened Escribe v1.2SP3 up with out the device attached and I went to the Power Ctrl profile which I believe is profile #6 then I saved that profile and named it ES Power. Then I attached the Therion and went to the Watts profile provided by Lost Vapes and loaded the profile from Escribe that I saved there and replaced the one from Lost Vapes with the standard one from Escribe and it takes care of everything. The Escribe profile has the voltage in the 2nd spot just for that profile without changing your other profiles. That's probably about as clear as mud. I would say watch the tutorial and maybe Busardos review on the DNA200. I replaced a lot of Lost Vapes profiles with either Escribes or Steam Engines but Escribes Power Ctrl profile is better then Lost Vapes.
Nevermind I answered my own question by going into the manufacturers setting and using the onboard calculator. That showed me that it uses the total of all cells for the WH's
Got it also on my VT133 I changed it to read LiPo 2 cells and 22.2 WH is that correct or are you supposed to show the WH for 1 cell and it takes care of the rest. I figured it wanted the total WH for both cells or in the case of a 3 cell LiPo the total of all three cells not just for one but I could be wrong on this. So what's the answer.
Just wondering on the Therion since it has 2 18650's in parallel. If you set it for Lipo, now here is my confusion, would you put Lipo 2cell 22.2 WH or would it be considered single cell 22.2 WH I haven't messed with mine since it seems to be working ok but if I did go into the manufacturers setting and set it for LiPo would it be considered 1 cell or 2. And when you change that are you supposed to put the total WH's or the SH's for 1 cell. Kind of confusing to me.
