shehabismail
Everything posted by shehabismail
Thanks. sucks to have this as the default
Hello, I got a new dna 250c mod, whenever i press the fire button and device gets up from sleep its locked and i have to press fire 5 times which is annoying. How can I disable that?
the board is outputting 13 amps and i have 3 18650s it will be 13/3 per cell?
Hello, I have set the mod to show the amps while taking a hit. question is is this amp per cell or total amps from all batteries?
Hello, why do evolv boards that use escribe have the option (or mandatory I dont know) battery discharge profiles? Why do we have to look for dual or triple or lipo discharge profiles and apply it to the mod? Is the watt hour setting enough? All other boards deal with this on their own without having the user to define these values
does that stand true for dna 60?
Hello I need to know how many amps are being used to charge the batteries inside the mod, also what is the setting to choose in escribe to make the mod show the charging amps. I can find it on DNA 200,250 but cannot find it for dna 60 or 75
Tried everything under the sun including this, ended up Sending it for RMA.
Already tried that, and resetteted current limit, tried everything but it was dead. changing it however this IC did fix 1 board but i still have 2 dead ones as seen on my pictures. This IC is very rare and i found it on the repair shop i visited. This shop is vape specific repair shop and they did the desolder and resolder themselves so i am unsure how they did it.
3 fried dna 250 boards and counting after months of research i nailed down the issue. its the balanced charging IC used, you need to RMA the board or desolder and install this faulty IC Check here
Hello, This is to discuess the charging issues on the DNA 250 "Balanced" charging chipset. I owned 2 devices, the Rebel 167 and Vaporshark 250. Both of them DIED and the reason was the charging IC is fried. I went to a local repair shop where I live and they told me this is a common issue and the IC needs to be desoldered and a new one installed and they didnt have stock. I had to buy New boards. I see multiple users complaining about 0% battery here and CHECK BATTERY status and in Lipo case not charging at all. Why did EVOLV use this faulty chip?
Therion 167/DNA250 0% batteries check
shehabismail replied to Kruchy9752's topic in Installation and Assembly
balanced charging ic was dead in my case (Rebel 167) and board needed to be replaced. -
Battery balanced charging IC is dead.
Hello, I need to know whether the Vaporshark DNA250 box mod uses a standark DNA 250 board or its custom made for them as I plan on replacing the board as it is dead
New Fullymax charging at 0.001 Amp
shehabismail replied to shehabismail's topic in Batteries and Charging
@Wayneo funny thing is right this very moment my rebel 167 throw error at me check battery and it doesnt fire anymore. i have 2 perfectly fine 30q in there!- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
@Wayneo I gave up and went to a local vape shop for repair. They suspect the issue is with the Charge IC above the usb port in attached photo they said they will try to work it out- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
@Wayneo something interesting. I removed the other white connector and when i did that the battery showed the charging lightning inside of it but still charges at the same o.o10 amps. as soon as i reattch it it gets out of charging mode- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
Im way beyond that...- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
@Wayneo The first battery died after 3 months i bought the mod and i left it until i got a new battery recently. The first one died in a similar fashion but i knew it died as 2 cells were below 1v and 1 cell was @ 3.7v and since i put this new battery yesterday it showed half full and couldnt charge it since then but the 3 cells are reporting similar voltages. I wonder the board still remembers the old decision it took to stop charging the first failed battery and is acting up the same with this new LiPo. It is the same exact lipo that came with it originally, the Fullymax 30c one- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
It is..- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
@Wayneo usb voltage is @ 5.337 volts i am not using it since i posted yesterday i had half of battery left and now its fully drained without usage (no way to shut down the mod except taking the battery out). I did attach the smaller white 4 pin one other than the negative and positive- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
@Wayneo No charging icon. I redownloaded escribe, same version i had previously installed. Full screenshot attached with the options I get when I click on Diagnostics- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
I tried the reset usb current limit still same issue is there- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
- 19 replies
- vaporshark
- fullymax
(and 1 more)
Tagged with:
