shehabismail
Everything posted by shehabismail
Start RMA Process if its still within warranty
Weird battery issues with DNA250C
shehabismail replied to shehabismail's topic in General Discussion
:Check attached snapshot from 2 different set of cells, and same cells showing this problem in the centaurus 250c (the stable screenshot) -
Not at all, its idle and everything is cleaned already. multiple sets of batteries show same behavior -
Hi So I have a Paranormal and Centarus DNA 250 C, I am getting weird battery readings like 19% while its full and i am using the correct battery curve csv. Batteries work fine on other mods and i tried 3 different sets. When i am looking at Escribe i see this. both batteries read way below the 4.2 and they are both freshly charged, one of them keep on dropping to 2. something and then back up to 3.4, any idea what is going on?
Hi Does anyone have dual battery VTC5d csv?
DNA 200 Battery Discharge Profile
After months of trial and error i finally fixed it, its a weird fix but hey it worked, so i am just dropping it here for the sake of helping any other user with this weird issue The problem: Cant load any battery profiles into the mod through escribe, you can see it on the first post where its "dimmed" and the buttons where you want to load a csv just wont load the window where you choose the csv from Tried: Resetting, hard reset, reinstall escribe, different cable, different pc all together, nothing, i have a lot of DNAs and this specific one was the one facing the problem, any other one worked normally Fix: Change battery type from Lithium Polymer to LifePo4 as soon as you do that, the graph shows again, change it back to Lithium Polymer and the graph remains and you can load your csv normally now and upload it to device, i think this is a bug and would like Evolv to take a look at it and even if they want to collect logs from me, no problem. -
Turnigy LiPo 950mah 3S 11.1v Curve
shehabismail replied to shehabismail's topic in EScribe, Software and Firmware
I understand but the turnigy is 950mah not 900 as the fullymax, this is why i was asking.. -
Hello, Does anyone have the discharge curve for this LiPo, I plan to use it in my Vaporshark DNA250. https://hobbyking.com/en_us/turnigy-nano-tech-950mah-3s-25-50c-lipo-pack.html Thanks
Same -
Yes ecigprofile loads normally -
My other 200s work, VT200, Releaux 200, Triade 200. I rebooted, reinstalled escribe. I am on Windows 10 x64. -
Hello, this is not device specific. I moved the board from a VT133 (still had this while the board was installed on it) to a Therion (same after moving). It is not that I cant add the CSV. The buttons themselves dont do anything when you press them. Any opther DNA 200,250 mods/board works normally, when I click on load csv the Window opens that asks for the csv. In this specific DNA200 board when i click Load nothing happens, as if i didnt click it, i dont even get prompted to provide the CSV. Its just that. As if you didnt even click it, and this is for this whole area. -
It is not the file that is the problem, the load/save/delete csv function doesnt work, i click on it and nothing happens, i have more than a dozen dna mods and they work normally. when i click the add/load/.delete csv files i get the prompt to choose the file. With this specific mod it doesnt bring/do anything, file attached anyway. 3300751.Sony_VTC4 (2)_18650_2100 mah_14.62 Wh.csv -
Same -
I understand, the thing is when i click load csv nothing happens, it doesnt open the window where i choose the csv file. Any other DNA mod works normally, but this one doesnt. -
Hello , On one of my DNA 200 devices, when i try to upload a dual battery profile i cant. The whole thing is kind of dimmed, i can do what i want on any other mod though, but this one i cant. Check attached screenshot. Help is appreciated
Atty works fine on other DNA devices in SS316L Temp control.
tried spaced coil. same issue. this is so frustrating, same clapton builds work fine on my other dna 200 and 250
Thank you, will try it
It should work even if its contact, my new Vaporesso GEN Works fine with the same build. Also it should work if the wire has SS or any other temp control material...
They are contact coils and 100% SS
Hello, I am using a clapton ss316L from advanced vape supply. When I am on replay mode, the first puff i like then i click save puff, then when i fire again it says check atomizer, replaced the coil and still same behaviour. Works fine in wattage mode. When I try SS316 it always says temp protect from the first puff. I am running latest software
Hello, How can I Configure my dna250c to show charging amps and amps while firing?
its evolv stock theme
I unticked this checkbox and uploaded settings to device, still same behavior
