TonyB
Everything posted by TonyB
  1. Hussar replaced/repaired the USB C port. It their own design not one like the charging board/USB C that Evolv can supply. I am now able to connect to Escribe using an Apple USB C - USB C cable as supplied with my new iPhone but using a small adapter to allow connection to my PC USB A port, so I have been able to make my usual adjustments to wire types and profiles etc……Hooray! Strangely my USB A to USB C cable from Anker didn’t work.
  2. Hussar are a good bunch, they will figure it out. Annoyingly I bought a decent quality cable from Anker and it didn't work, I did try and flip it. Yes its the Boro type device with the New Cimi connection system
  3. Hi Wayneo The mod is the Hussar C1 - just released. Its a cable issue as far as we can tell. The use their own USB C port and some cables work and some don't they are looking in to it to find out which cable to use. Not ideal but I have been in contact with them and they didn't realise that this was an issue.
  4. I have a new mod that I can't seem to connect properly to my PC or Escribe (its not being seen by the PC). I thought it might be a cable issue as the USB C port is quite tight but I have tried filing down the plastic on one of my cables to allow the plug to go in fully but it still won't connect. The mod does power on when connected but its not connecting fully, the PC doesn't see it. I have tried a different quality cable as well but it still won't connect. I have the latest version of Escribe 2.0 SP57 installed. Other mods connect just fine. Thoughts on this please.
  5. Yes DNA60. I’m actually using a 316L profile that Daniel from YouTube channel DJLSB vapes did years ago. He had noted that the stock DNA profile was a bit off. I’ve used it for years. it seems to have settled down now. I might try the tests below and see what the produces. Thanks for your input so far.
  6. I’m using a rebuildable RTA Hussar Avant. The wire profile 316L SS is correct it’s the same one I’ve been using for years on all my DNA boards and has always worked.
  7. I’ve been messing with a troublesome Atty that works in TC ok initially then after a refill or when I mess with settings on the mod switches in to a power/watts mode and won’t switch back to TC even though I’m using a TC set profile. I’m using 316L SS wire. I went in to Escribe after a clean up let it cool down took an Atomiser reading and locked the ohms. It worked for half a tank but I tried to see if I could adjust the Pre-heat which I had zero’d out previously in Escribe. Well I couldn’t figure out how to adjust pre-heat on the mod for TC, only for Wattage mode, so is that change only possible in Escribe for TC mode. what can I do to get my mod to switch back to TC when it’s switched over to Power/Watts and won’t switch back?
  8. TonyB
    mod resistance
  9. Buy some 21700 batteries, sound like your battery is past its best.
  10. Just got the same mod. As you have discovered its only loaded with the Stock Evolv Theme and its missing so much. If you can get your brain round it I recommend creating your own or downloading one of the more recent Themes (with Replay) from the Themes Topic on the forum. You can rename any of the Profiles and change how they work and with which ever wire you choose. Rename the Nichrome as Watts for example.
  11. It would have been nice of Evolv if they had actually given us a guide to creating themes that work as we want them to with an explanation of what all the different settings do (as many sound or look similar but function differently) instead of leaving us to reverse engineer or fumble/guess our way through the settings in order to achieve what we want. HOW ABOUT IT EVOLV ? - I don't know if it exists but it would have been a great help instead of me spending a great deal of time tweaking settings to get this right.
  12. My mod currently changes temperature settings in 5 degree increments. How do I change that to 1 degree increments?
  13. I'm running the very latest version SP25 on a new SVA DNA75c. What statistics are supposed to be re- set with that function set up as it doesn't appear to be doing anything. Can't seem to re-set any of the puff info either. I've been tweaking the installed theme that came with the mod, but there are a couple do things that don't seem correct - Changing the temp the up/ down buttons are crossed to hitting what should be down (lower) actually raises the temp setting, same with power on the main screen. But on the Pre-Heat Punch screen adjusting the temp works the correct way.
  14. TonyB
    DNA 60
    I'm waiting for some new mods to appear. I guess the board is not widely available yet. @turbocad6 - That is exactly what I want! Small DNA60 Squonk mod. That looks amazing.
