Jasonvillamil
Everything posted by Jasonvillamil
  1. Unfortunately I didn't take pictures when I had the door apart. Essentially, the Mirage door is metal on the outside, with plastic on the inside held with two tiny plastic clips and some 3M sticky tape. I have two Mirage mods, both of which have failed; the door on each has popped open, as all of the weight of the battery is on the two plastic tabs that aren't anywhere nearly strong enough to support the weight. This in my opinion is a design defect, and I'd suspect that most of these mods will break in this way over time. My fix was pretty simple: took apart the metal and plastic door, removed the tape, and applied a very strong epoxy. You have to be very careful, as too much epoxy will seal the door lock slider and the door will be useless. Overall it only takes a few minutes to loosen the two screws, remove the door and apply the epoxy. Compress it and let it set overnight, and you're back in business.
  2. Checkout my Enhanced Default DNA 75/250C theme that is posted; for international firmware, it allows both boost and preheat, depending on whether the profile is set to wattage or temp mode, and allows adjustment of the punch. Also fully updated for Replay.
  3. You can search around the forum; know this is a popular squonk mod. If you can’t find anything, keep the mod internal resistance at the factory setting if it came with one; if not, set to 0.0034; that’s 85% of .004, which is on par for all lost Vape mods that I’ve seen. You can then run a thermal analysis using Escribe; very easy to do. For battery profile, you can just use the Escribe default for an 18650.
  4. Technically you could use these settings as a starting point. However, as the squonker is a different mod, the following settings should be changed: internal mod resistance mod thermal profile battery profile for your specific batteries
  5. In my experience, the battery profile curve will affect the fully-charged upper voltage reading. Not an actual performance issue, but we want the voltage and percentage to show correctly; best bet is to run your own battery analysis while the battery is pretty new, or download one that matches your exact battery.
  6. 0.01 ohm is definitely incorrect; far too high for internal resistance. I measured 0.004 with a copper plug and set it to 80% of that, or 0.0032. You can use that value as a safe measure on both mods if you don’t own a plug to take your own measure.
  7. I don't believe so; if I remember correctly, the early betas of Boost allowed wattage and time to be specified; however, the latest iteration condenses these into the Punch factor. I'm assuming punch is an aggregate measure of power plus time, on a scale of 1 to 11. Don't quote me on this though
  8. @PatrickSmith SP12 is the Escribe version, which is the latest beta for the 75C (there is a v13, but it’s only has updates for the 250C) SP27 is indeed the latest beta firmware for the 75C. Concerning boost, make sure you’re in wattage mode, enable boost, and set the punch to a value between 1 and 11, preferably around 7 for testing. Take a puff and check the monitor; you should see a spike. Note that your wattage will need to be somewhere below 75 to see a boost, or you can check that the maximum output wattage is set to 100 in Escribe to boost past 75W.
  9. About 10k puffs into a Mirage 75C; really great mod. The finish is top-notch, and love the resin and low weight. Single battery doesn't pack as much punch as dual, but you can get a good 2x700 battery with a high mAh rating. Only issue with the mod is the battery door: I dropped mine and the door split open. It's held together by double-stick tape and two tiny plastic clips. Removed the sticky tape and used epoxy to reseal it, and it's good as new, if not better. Well worth it!
  10. Absolutely! I have a new version of my DNA 75C Enhanced Default theme on standby ready to implement Replay; cannot wait for it to be released as it looks like a real game changer. Hopefully Evolv will have a beta up very soon. Concerning the new mod, reminder that you can use any Theme that you want; there are some really great ones posted. This specific file is more about customized settings specific to the Mirage mod, and also happens to include my custom theme as that’s what I run on all of my 75C’s.
  11. @mactavish Congratulations on the new Mirage! This posted EScribe settings file is already pre-configured to support 100W via the boost feature. You'll want to be sure to install EScribe International version v2.0 SP12 or higher, and apply beta firmware v1.1 SP27 or higher to your new mod. You can then verify in EScribe under Mod, Safety, that the Max Output Power is set to 100W. Correct concerning batteries; if you're using a single 18650, you can either download a battery profile for your specific battery, or use the EScribe 18650 default. To use the default, go to the Mod, Battery tab. Under Type, change it to Lithium Polymer temporarily, then back to Lithium Ion 18650. That will wipe out the iJoy 21700 profile with the default 18650, and you're all set. Concerning battery safety, be sure to set the Max Peak and Sustained Input Currents to the ratings for your specific 18650 battery. Don't want to draw 24A sustained if the battery isn't rated for it! Hope you enjoy!
  12. Version 1.0.0
    1,568 downloads
    This is a fully configured Escribe settings file for the new Lost Vape Mirage DNA 75C. Highlights: All 8 profiles configured, with: 3 temp control profiles for favorite atomizer and build combos. My go-to is the Pharaoh RTA as the primary profile, plus the Crown III and the SMOK Baby Beast for emergencies while traveling 5 power-only profiles, at presets of 35, 40, 45, 50 watts Includes my posted DNA 75C Enhanced Default Theme v2.2 which greatly expands the stock theme's capabilities Standard materials plus two SS316L materials, one curve and one TCR set at 0.00094 Mod fully configured: Battery Analyzer run for iJoy 21700 3750 mAh 40A battery Cell Soft Cutoff set to 2.75V, max sustained discharge at 24A, max peak discharge at 35A for longer cell life Output currents set at DNA 75C spec sheet typical rating Mod internal resistance at 0.0031 ohms, measured with copper plug (actual 0.004 x 80%, minus an extra 0.1 mOhm for kick(s) Built for EScribe Suite International v2.0 SP12 or higher, running beta firmware v1.1 SP27 or higher Hope everyone enjoys!
  13. I wouldn't really recommend it; a different mod and battery will have differences in thermal profile, battery profile, internal resistance, etc. Would be better to configure the Boxer by hand using EScribe's case and battery analyzers.
  14. EScribe battery profile CSV for the iJoy 21700 3750 mAh 40A battery. Couldn't find this anywhere so went ahead and ran the analyzer to create it; hope it helps! For reference, this battery came in right at 10.575 Wh. Per Mooch's tests, recommended maximum sustained input current of 24A, maximum peak input current of 40A, and a cell soft cutoff at or above 2.75V. iJoy 21700 3750 mAh 40A.csv
  15. Confirmed that upgrade to the international Windows Escribe version and v2.0 SP6 firmware has been running for several days without issue. Loving the boost functionality as well1
  16. Be sure that the field Source is Coil Temperature. Click Options, and set the Step Size to the desired increment: Hit OK, and be sure to Apply the theme, and upload the changes to your mod.
  17. You can use the theme editor to select the wattage text field. Modify it and you can then change the increment.
  18. @Smokin Dave This was actually intentional before I'd read posts about this causing extended battery drain. Version 1.9 just uploaded removes the LED staying on until the mod sleeps. This version is up and also includes other changes to the Performance screen. Check it out!
  19. Peraspera, you can use the Therion out of the box, but earlier versions did come uncofigured at default settings. If you’re going to use Ni or Ti, the safe bet would be to review the material and Mod tab settings in Escribe first. If you only have a Mac, you could run Escribe in a virtual environment. I posted a fully configured Therion settings file to the download section of the forum as a starting point for mod safety limits if need be. As far as firmware goes, the stock firmware is fine, though I’d recommend the beta from the “ohms too low” thread, as it helps to correct the resistance measurement which is needed for accurate temp control.
  20. @67exec I'm assuming you're seeing this in the Profile field, above the wattage / temp+wattage fields on the main screen? Not exactly sure how this is possible, as that field is assigned to display the selected profile Name. and not coil material. Did you check your profiles in EScribe to ensure they're named properly? Check that when you get a chance, and maybe try applying the new v1.7 theme just uploaded and see if that helps.
  21. @James I've had a day with the beta and performance is definitely much better. Tested two single coil builds against my two DNA250 mods and the beta DNA75C, and the resistance readings are spot on. This with 0.004 internal mod resistance as measured, and the 250's set with their own respective internal resistance. I did some testing with room temp, and believe that the 75C only seems to update room temp after the mod goes to sleep, or after a reboot. This explains the big jumps I'd mentioned earlier: I'd watch room temp sit at 73 degrees, vape a bit and then let it sleep, with room temp never changing. Picking the mod up ten minutes later then showed a refresh, which would bring room temp way up, as obviously the mod is much warmer after having been used recently. I tried the default profile's thermal settings, but room temp is way off when cold; I decided to instead stay with my results averaged with @ndb's results, and room temp is pretty close to actual when the mod is truly cold. I think what also helped a lot is reducing min and max room temp to a narrower band, 60-90 degrees. Note that after vaping a bit, room temp will always hit the max ambient 90 degrees if I let the mod sleep or do a soft reboot. However, the vape has still been very good, having left the cold ohm reading when the mod was actually cold and room temp was true. So, much, much happier so far with the DNA75C running the beta firmware! Will try another build this evening and will update if anything weird happens. Key settings for reference if anyone else wants to try the beta and wants a reference point: SS316L: Curve set at Stem Engine CSV curve Therion internal mod resistance: 0.004 Case thermals earlier in this thread Min ambient of 60, max ambient of 90
  22. James, Trying out the provided v1.1.SP22 Beta 1 service pack. Cold ohm reading jumped 0.013 ohms on the first coil tried, and the vape is definitely better. Had to drop TCR for SS316L down from Daniel's 0.001 to 0.00094 to keep from a burnt taste. I'm wording what is new in this firmware release? Was an offset entered in firmware, or something else? Should we be dropping our TCR back down to published resistivity for stainless? On another note, I've experienced over the last few days that the 75C's cold ohm reading and quality of vape in TC mode greatly depends on the associated room temp reading on the board when the cold ohms were measured. The problem is that I've seen the Therion room temp reading vary greatly, from 65 degF all the way to 88 degF, even when sitting still in a level 73 degF room. I've taken to reading cold ohms, then manually setting the recorded room temp to whatever the board happens to be showing as room temp at the time to get it consistent. Any ideas on this? Thanks for the beta firmware and input!
  23. Shinn, I experienced the same issues as you at first. The Therion comes with default reference settings unfortunately, which means it basically needs to be fully configured before it will give you a good vape. To start, you need to run the Case Analyzer. Set the mod on a table, make sure batteries are about a quarter to a half charged, try to measure the surrounding temp, and let the analyzer run. Be sure to upgrade to the latest version of Escrive first to make sure you don't get an error when you upload the settings. You can optionally attach an atomizer to better represent the full thermal dynamics as when you vape. That will greatly fix the cold resistance readings and room temp reading. I'd also recommend manually re-reading cold ohms every time your atomizer is cold; this is what the other DNA chips do, and wish the 75C did. There are many more settings to configure, such as input and output currents, battery profile, internal resistance etc; I actually just posted a copy of my Escribe settings for this mod, fully configured, to the downloads section of the forum; once approved, take a look for some of these settings in my file if need be. If you'd like a copy now, just let me know. Hope this helps!
  24. Version 1.2.3
    3,468 downloads
    This is a fully configured Escribe settings file for the new Lost Vape Therion DNA 75C. The mod basically came unconfigured at the stock board settings which was surprising. This config file has been meticulously configured, and includes the following highlights: All 8 profiles configured, with: 3 temp control profiles for favorite atomizer and build combos. My go-to is the Pharaoh RTA as the primary profile, plus the Crown III and the SMOK Baby Beast for emergencies while traveling 5 power-only profiles, at presets of 35, 40, 45, 50 watts Includes my posted DNA 75C Enhanced Default Theme v2.2 which greatly expands the stock theme's capabilities Standard materials plus two SS316L materials, one curve and one TCR set at 0.00094 Mod fully configured: Battery Analyzer run for dual HohmTech Life 3000mah 18.04wh 18650's Cell Soft Cutoff set to lower limit of these 18650's at 2.9v to protect the batteries Input currents set for battery safety based on Mooch's test results Output currents set at DNA 75C spec sheet typical rating Mod internal resistance measured with copper plug at 0.004 ohms Case Analyzer run at 73 degF ambient, averaged over 3 runs Hope everyone enjoys!
  25. Results from Case Analyzer for Lost Vape Therion DNA 75C: Case Cooling Time Constant: 155.84 s Case Heating Time Constant: 317.27 s Case Static Temp Rise: 10.47 degF Case USB Connect Temp Rise: 0 degF Case USB Charge Temp Rise: 23.6 degF/Amp
