Remix of SirTimmyTimbit's Gauges theme, the default Evolv theme, and a few custom touches.
  • UI from Gauges, but without the gauges. Instead there's a minigraph. Click it to go to the full Puff Info screen.
  • Status bar at top of Main and Menu screens shows battery level and Cold Ohms when idle, Live Ohms while firing, and USB current while charging.
  • Last Puff Time and Last Puff Average Power are displayed in small font below the minigraph.
    • In TC modes, Power is below the minigraph in normal font, and Temperature is in the large font.
    • In TC + Replay, Temperature is below the minigraph
    • In TC + Replay with a puff saved, Last Puff Average Temperature is below the minigraph.
  • Profile editing allows Temperature to be edited when Replay is enabled. DNA supports TC+Replay so this theme does as well.
  • Classic/New UI switch moved to Display options.
  • Indicator LED stays green while mod is idle, goes out in lock/standby:
    • The DNA writes the current settings when this light goes out. If you pull the batteries while the LED is on, you'll lose your changes!
  •  Menu is icon grid from Digital.
What's New in Version 1.3.3   See changelog
  • Main screen clean up, elements are less crowded and graph is larger
  • Lock and Main no longer have (nonexistent) wallpapers selected. This might fix the occasional "Error Press Up" on wake, not sure.
