The theme is based on my previous topics. It works on DNA75C DNA250C, and in DNA75C does not operate "Power bank" mode.
The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution.
Copy from VapingBad
The TP icon:
default shows on image,
Text status:
Temp Field:
atty\temp as default
Extras:
In Lock Screen down: Current in charge or root temperature in non charging mode.
In Main Screen two resistans: locked ohms and life ohms.
In Main Screen right to Power:  temperature of board or output voltage in VW mode.
In Main Screen right to Temperature: Temperature ot last puff
Screenshot for Simple version:
Lock-screen-charge.pngLock-screen.pngMain-screen-TC.pngWatt.pngReplay-ready.pngReplay-save.pngPlaying.pngPower-bank-off.pngPower-bank-on.pngPreheat-off.pngPreheat-on.png
Screenshot for extended version:
Lock-screen-charge.pngLock-screen.pngMain-screen-TC.pngWatt.pngPlaying-ready.pngPlaying-save.pngPlaying.pngPower-bank-off.pngPower-bank-on.pngPreheat-off.pngPreheat-on.png
Copyman-Gothic-III.ecigtheme
Copyman-Gothic-IV.ecigtheme
Copyman-Gothic-IV-simple.ecigtheme
What's New in Version 1.0.2   See changelog
Change font - Previous font was very unreadable!
The Wolfy Vape
Fantastic design.  I had to delete two panels in order to install it onto my box. I deleted the Powerbank page, and the live recording page, and also deleted the icons for those pages on the menu screen, as I don't use those two pages.  But other than that, it's perfect.  I love that it has to option to change the wallpapers of each screen to skulls, as my box is all skulled out.  Everything works perfectly. Great job, and thanks for the hard work!
Tmease
· Edited by Tmease
Fantastic theme. I had been using Gothic-II Simple theme for months and months now, and I just uploaded the Gothic-III to my Paranormal(non simple version). The first was really impressive!  Battery info still shows data of 4 batteries, when my mod only holds 2.  The non- batteries appear darker on the screen.
Hello,
New version - 1.0.5. Modified battery information screen. Now missing battery information is not displayed. Thanks for the interest and kind words!
Dougvapes
Really like the theme. I’m new to dna250c and escribe but this was my first theme I’m trying. The only thing I don’t understand is why it shows four battery cells when I only have 3.
Hello, my mistake, because my mod has four batteries and I have not paid attention to hiding batteries that are not present. I'll upload the theme with the fix now ..
Canadianvape
It has everything I need and in 0.1w and 1degree increments, has everything on the device so you only have to plug in to update, great work!
Adding  0,1W and 0,1 degree increments.  0,1 increments is available only for the simplified theme - Gothic Simple III, the other theme (expanded theme)  is not changed because of the lack of space. The small font in this place will not be read well
The Vapor Ninja
This is a great theme.
It's got all the information displayed, with SO many options !
Really excellent work, I have offered it on my site.
Works with 100C, 75C, and 250C.
Nice work ! This is among my favorite themes of all time !!!
Kais83
I absolutely love everything about this theme on my ZQ Essent!  The one and only issue I have is on the Replay screen, there's a little red flash that occurs intermittently for both REPLAY READY and SAVE PUFF icons (appears to be in the temperature field).  Once I have a puff saved, this does not occur with the STOP REPLAY icon.  Thank you for all the hard work, the theme is GORGEOUS!
