Green Ohm - English/Deutsch 4.2
   (4 reviews)
Preheat (Boost) für den Watt-Mode! --- English versions for countries with date format m/d/yy (U.S.) and d/m/yy (UK/AU) available.
Stealth Level:
  • 0: Stealth aus
LED im Feuer-Taster:
  • Lila: Feuern
Viel Spaß
Andy
What's New in Version 2.0   See changelog
AtomiX1
It's nearly perfect for my needs, but there's something of main importance missing, the REPLAY function.
Please, see if you can add it and I will give the fifth star ;)
Thanks
mackman
Really like the ease of the layout and overall look of thea theme on the screen
Can only hope his themes are updated to include replay
RoMe60
... WAU ...
Du hast ja alle Deine Theme überarbeitet :relaxed:
Sieht SUPER aus ... Kompliment ...
Kann mein Favorit werden :love:
