Same functionality as my other themes. Loads of colour!
US version: Date format m.d.yy and spelling e.g. atomizer
UK/AU version: Date format d.m.yy and spelling e.g. atomiser
Features / how to use:
   etc. etc... Please note that you won't actually see 'DNA' on the screen, only relevant text.
-Selecting the coil material on the Main Screen takes you directly to atomiser settings. Note that coil material is not displayed if you are in wattage mode.
-Most screens feature a 'Back' or 'Exit' button or a combination of both. 'Back' will take you back to the screen you came from, e.g. if you go to Atomiser Settings from the Settings Menu the back button will take you back to the Settings Menu. If you go to Atomiser Settings by selecting the coil material on the Main Screen, the Back button will take you back to the Main Screen. In all cases the Exit button will take you directly to the Main Screen.
-Black background on the Device Monitor, Diagnostic and Device Info screens to make the text easier to see and read.
-Screens you can fire from: Main Screen (obviously), Atomiser Settings, Device Monitor and Diagnostic. Pressing the fire button on any other screen will give the same result as selecting 'Back'. e.g. if you are on the Display Settings screen you can press the fire button twice to go back to the Main Screen- pressing once goes back to the Settings Menu and another press takes you back to the Main Screen.
-Board temperature and battery voltage are displayed at the bottom of the Main Screen.
  3 = Screen turns off
  2 = Very dim
  1 = Dim
-Indicator light:
  Fade in/out red = charging
  Green = charge complete
  Blue/purple = firing
Enjoy!
EGO 13
Great theme !
But I have a small problem . when I press fire on main screen the TC indicator disapear .
And If I choose watt mode in one of my profiles : TC and Watt indacator dispear also .
Anyway congratulations for this theme :thumb::)
rob cuisinier
verry nice jake t thanks :)
this file is this not to big fore my device?
                                            mvg rob.;)
