Hi all! I have a nice Cento theme for the DNA100C and want to install it on a DNA75C mod. I can only install the theme file (.theme), but not the settings file (.settings)—which contains the profiles, configurations, etc.—because I get a "DNA100C mod not connected" error.
Is there a way to get around this? I’ve shown the issue in the photo.
That's right. You can save profiles from one and move to the other individually. Same for a battery curve and material profiles.
2 часа назад, Wayneo сказал:
If I just load the TС profiles (Nife30, nife48, ss316L) instead of the standard ones, will they work the same way? Or do I need to load the "materials" separately as well? That’s so inconvenient... Also, how do I load a separate battery curve? Thanks for the answer!
If I remember correctly for material files, on the left window you'll see all available (from all your mods) and the right window is what's on an individual mod. *You can't delete a material file from a mod if it'a assigned to a profile* So they'll work the same on all mods.
If you use multiple vendors or never changed yours, you might as well live with the evolv default. Otherwise it's under 'Mod' battery.
