Wayneo Posted June 23 Report Posted June 23 Evolv/James has added a 'loop checker' in escribe SP77 that checks the theme installed on a mod when one does 'upload settings to mod'. This stops the upload, describes the error and causes the user to have to install a 'clean' theme before continuing. James' words 'That error is because I added a loop checker, which detects if a screen jumps to another screen that jumps back to the previous screen, all using "Go To Child Screen", which can run out the screen stack.' Because of this, and how the user interacts with the theme, it can cause 'menu error' or that other oddity 'press left' due to a stack overflow. Read the 'error' carefully and follow the instructions to fix it. You have 2 choices. Either test your own theme now by simply using SP77 OR LATER and trying to install then upload to your mod or if a user gets the error, we will hide your theme until it is fixed and tested by you. Of course we will send you an email when we hide your theme.
Dragan Čelebić Posted 13 hours ago Report Posted 13 hours ago (edited) How can I get around this restriction 'loop checker'? I carefully read your instructions, SP76 is not available for download. What next? Thanks On 6/23/2026 at 1:10 PM, Wayneo said: Evolv/James has added a 'loop checker' in escribe SP77 that checks the theme installed on a mod when one does 'upload settings to mod'. This stops the upload, describes the error and causes the user to have to install a 'clean' theme before continuing. James' words 'That error is because I added a loop checker, which detects if a screen jumps to another screen that jumps back to the previous screen, all using "Go To Child Screen", which can run out the screen stack.' Because of this, and how the user interacts with the theme, it can cause 'menu error' or that other oddity 'press left' due to a stack overflow. Read the 'error' carefully and follow the instructions to fix it. You have 2 choices. Either test your own theme now by simply using SP76 OR LATER and trying to install then upload to your mod or if a user gets the error, we will hide your theme until it is fixed and tested by you. Of course we will send you an email when we hide your theme. Edited 13 hours ago by Dragan Čelebić text correction
Dragan Čelebić Posted 13 hours ago Report Posted 13 hours ago I solved the problem by installing EScribe2_SP57_INT_ServicePack Thanks for the space
Wayneo Posted 11 hours ago Author Report Posted 11 hours ago 1 hour ago, Dragan Čelebić said: How can I get around this restriction 'loop checker'? You should write a comment on the theme for the author to see it and fix it. 1 hour ago, Dragan Čelebić said: I carefully read your instructions, SP76 is not available for download. What next? By the time I had written that, SP76 was removed and replaced by SP77 (which you quoted). 1 hour ago, Dragan Čelebić said: I solved the problem by installing EScribe2_SP57_INT_ServicePack That's certainly one way to get around a buggy theme and any minor enhancements. 1
