May I ask why Traditional Chinese cannot be added to the text content?
If I use Traditional Chinese, I would need to add many additional images. I hope Traditional Chinese can be added to the font library.
Traditional Chinese is available on the PC side. However, on the device itself, displaying the theme language in Traditional Chinese currently requires adding image assets instead of using system fonts.
  • 1 month later...
In Theme Designer, go to Appearance -> Fonts and select a font that has the characters you want to use. The default theme uses the Built font, which has a limited character set, but you absolutely can choose a different font.
(You can also add a secondary font if you want, if you want to use a font with limited character set, but have another font be used if the character is missing from the primary font.)
