jinx'd Posted April 27, 2025 Report Posted April 27, 2025 hello i have a problem with this. i only use it 2 nights a week while i am having a few beers. i put the batteries in and it goes to temp control, all i ever use it for is watt boost. i have been taking the batteries out however many times to get it to sort out, but last night it would not. i also tried switching themes, didn't work. i never use temp control so idk just what may be happening here. please advise. thanx
Wayneo Posted April 27, 2025 Report Posted April 27, 2025 39 minutes ago, jinx'd said: .................i put the batteries in and it goes to temp control, all i ever use it for is watt boost What do you mean by that?
jinx'd Posted April 27, 2025 Author Report Posted April 27, 2025 it goes straight to temp mode, and idk how to adjust it to work in that. and even though the screen says watt boost, when i hit the fire button it says temp protect and doesn't fire.
Wayneo Posted April 27, 2025 Report Posted April 27, 2025 22 minutes ago, jinx'd said: .......... when i hit the fire button it says temp protect Aaaaah, that is not 'temp mode', just a poorly worded informational message that can have many reasons. The most common reason are an ohms mismatch or runaway ohms. You should remeasure your coil Ω's and try to see if that was it, failing that you should check your coil. Let me know your outcome.
jinx'd Posted April 28, 2025 Author Report Posted April 28, 2025 it goes straight to temp mode, and idk how to adjust it to work in that. and even though the screen says watt boost, when i hit the fire button it says temp protect and doesn't fire. yeah, but the DR works fine on other DNA mods, Paranormal. and when i can get this one to work, it works fine.
Wayneo Posted April 28, 2025 Report Posted April 28, 2025 Start escribe with your mod plugged in, navigate to your ‘watt boost’ profile and do a screenshot. Post it here screenshot instructions in my signature line
Wayneo Posted April 29, 2025 Report Posted April 29, 2025 Yup, that was perfect. That all looks pretty normal. Did you remeasure the Ω's of your coil?, the photo showed 0.11Ω's, now 0.19Ω. Do you have another atty you can try on this mod? Remeasure ohms with it before use.
jinx'd Posted April 29, 2025 Author Report Posted April 29, 2025 i just tried a diff rta on it, it is fine. but, sometimes it didn't do it. now i just put the DR on it, still ok. the coil remeasures a lot.
Wayneo Posted April 29, 2025 Report Posted April 29, 2025 See how in your screenshot near the bottom across from material it shows 'Watts' ? So you were never in TC. If it happens in the future, follow what I said.
jinx'd Posted April 30, 2025 Author Report Posted April 30, 2025 i never purposely set to TC cause i have no use for it. i will investigate the next time it happens.
Wayneo Posted April 30, 2025 Report Posted April 30, 2025 IT WAS NEVER IN TC. On 4/27/2025 at 3:12 PM, Wayneo said: Aaaaah, that is not 'temp mode', just a poorly worded informational message that can have many reasons. The most common reason are an ohms mismatch or runaway ohms. You should remeasure your coil Ω's and try to see if that was it, failing that you should check your coil.
jinx'd Posted May 3, 2025 Author Report Posted May 3, 2025 temp protect. it did it last night. so i swapped to my QPmini that i use every day, it worked fine. then i flipped over the dead rabbit and sure enough, the 510's were filthy. i cleaned and all is working fine. so, i'm a dope, lol. the thing is this DR never leaks, or so i thought, it must be extremely small leak at the 510 pin.
Wayneo Posted May 3, 2025 Report Posted May 3, 2025 You're welcome. I'm gonna change the subject title to better reflect the issue. Hope you don't mind. 1
jinx'd Posted May 4, 2025 Author Report Posted May 4, 2025 20 hours ago, Wayneo said: You're welcome. I'm gonna change the subject title to better reflect the issue. Hope you don't mind. you should have changed it to = don't be a dope, lol 1
