hello
i have a problem with this. i only use it 2 nights a week while i am having a few beers. i put the batteries in and it goes to temp control, all i ever use it for is watt boost. i have been taking the batteries out however many times to get it to sort out, but last night it would not. i also tried switching themes, didn't work. i never use temp control so idk just what may be happening here. please advise. thanx
it goes straight to temp mode, and idk how to adjust it to work in that. and even though the screen says watt boost, when i hit the fire button it says temp protect and doesn't fire.
22 minutes ago, jinx'd said:
.......... when i hit the fire button it says temp protect
Aaaaah, that is not 'temp mode', just a poorly worded informational message that can have many reasons. The most common reason are an ohms mismatch or runaway ohms. You should remeasure your coil Ω's and try to see if that was it, failing that you should check your coil.
Let me know your outcome.
yeah, but the DR works fine on other DNA mods, Paranormal. and when i can get this one to work, it works fine.
Yup, that was perfect. That all looks pretty normal. Did you remeasure the Ω's of your coil?, the photo showed 0.11Ω's, now 0.19Ω.
Do you have another atty you can try on this mod? Remeasure ohms with it before use.
