n82freak Posted April 12 Report Posted April 12 Hello. I'm suddenly having problems with my Dovpo Riva. The device says the battery only has 4%. I charge my batteries in an external charger. The batteries are fully charged and technically fine, and are recognized perfectly by every other device. I've already completely disassembled the Dovpo Riva and checked it for liquid or corrosion. No liquid has penetrated and the board also looks fine. I then downloaded the eScribe software. The device is recognized and can be read. Installing the latest firmware was also not a problem. I can't find any problem. Perhaps someone here has an idea how to solve this problem.
Wayneo Posted April 12 Report Posted April 12 Did you ever click 'Restore Defaults' in escribe? I need you to go into escribe (with mod plugged in), then start 'Device Monitor' and do a full screenshot. No need to take a puff.
n82freak Posted April 12 Author Report Posted April 12 Gerade eben schrieb Wayneo: Did you ever click 'Restore Defaults' in escribe? I need you to go into escribe (with mod plugged in), then start 'Device Monitor' and do a full screenshot. No need to take a puff. Yes. Before i installed the actual firmware, i do a complete reset.
Wayneo Posted April 12 Report Posted April 12 OK, then also (in escribe) click 'mod' -> 'battery' and do another full screenshot
n82freak Posted April 12 Author Report Posted April 12 (edited) vor 26 Minuten schrieb Wayneo: OK, then also (in escribe) click 'mod' -> 'battery' and do another full screenshot Ok. Here some Screenshots. Edited April 12 by n82freak
Wayneo Posted April 12 Report Posted April 12 Thank you. There's all sorts going on there. You need to change your battery specs back to normal. For 'size class' that should be back at 'normal', and 'cell soft cutoff' 2.75 volts. Then 'upload settings to mod' From 'Device Monitor', look at your 'cell 2' it's showing 1.1v. That is the problem. Unplug mod, physically swap your battery positions in the mod. Plug mod back in restart esribe -> device monitor. If cell 2 still shows a low voltage it is your mod wiring or connection. If cell 1 is now low it is a dead battery. 1
n82freak Posted April 12 Author Report Posted April 12 vor 1 Minute schrieb Wayneo: Thank you. There's all sorts going on there. You need to change your battery specs back to normal. For 'size class' that should be back at 'normal', and 'cell soft cutoff' 2.75 volts. Then 'upload settings to mod' From 'Device Monitor', look at your 'cell 2' it's showing 1.1v. That is the problem. Unplug mod, physically swap your battery positions in the mod. Plug mod back in restart esribe -> device monitor. If cell 2 still shows a low voltage it is your mod wiring or connection. If cell 1 is now low it is a dead battery. Thanks. Yes. It is not the battery. If swap them, always Cell2 shows smaller voltage. So we know the Battery is Ok and there is a Problem by wiring or bord. I check all cables. There is nothing wrong. Is it possible that the bord have defects? What can i do to find out?
Wayneo Posted April 12 Report Posted April 12 Definitely not a bug, not a board problem. Wiring or connector problem. Do you have a multimeter? I have never seen the innards of a Riva, but you could check the voltage shown for cell 2, and what the board sees. 1
n82freak Posted April 12 Author Report Posted April 12 vor 2 Minuten schrieb Wayneo: Definitely not a bug, not a board problem. Wiring or connector problem. Do you have a multimeter? I have never seen the innards of a Riva, but you could check the voltage shown for cell 2, and what the board sees. The Cells are fine. I use an external charger.(xtar VC45L) with complete battery-health-check. So i disassemble my Riva tommorow again. Then i do some pictures and test all wires by multimeter again. I hope i can rescue my vape. Thx a lot for your help. I give tommorow some updates here.
Wayneo Posted April 12 Report Posted April 12 The bottom of the board has like a little longer section. Is there a white (JST) connector there, or are there some thin wires directly attached to the board? Just a photo or 2 of that area would be good. 1
n82freak Posted April 13 Author Report Posted April 13 (edited) vor 12 Stunden schrieb Wayneo: The bottom of the board has like a little longer section. Is there a white (JST) connector there, or are there some thin wires directly attached to the board? Just a photo or 2 of that area would be good. I am not shure but i think i found the "bug"! There is a little red cable wich have no contact to the board. I think it should go the first pin at the same side. I solved the cable. But the board show the same wrong mesurement as before. I dont know what to do. Now i think the board is broken. Edited April 13 by n82freak
dwcraig1 Posted April 13 Report Posted April 13 Either with wire or solder bridge. G and B- need to be bridged together. Then 2,3, 4 and B+ need to be bridged together. The yellow is cell #1 positive.
n82freak Posted April 15 Author Report Posted April 15 (edited) Am 13.4.2025 um 13:04 schrieb dwcraig1: Either with wire or solder bridge. G and B- need to be bridged together. Then 2,3, 4 and B+ need to be bridged together. The yellow is cell #1 positive. Hi.. i sold it like your picture. Now intern at the Diagnosticscreen from Vape it shows 7.2 Volts but at normal screen it shows 4% and check batteries. Edited April 15 by n82freak
Wayneo Posted April 15 Report Posted April 15 On 4/12/2025 at 4:19 PM, Wayneo said: From 'Device Monitor', look at your 'cell 2' it's showing 1.1v. That is the problem. ............... DO YOU SEE ME POST %'s IN MY POSTS? Now look at your cells. You really need to redo that soldering or clean it up so solder is only each pad from ground, pin 1, and pin2. I'll tell you from now, if I see a single % in anymore of your posts, someone else can help you.
n82freak Posted April 15 Author Report Posted April 15 vor 59 Minuten schrieb Wayneo: DO YOU SEE ME POST %'s IN MY POSTS? Now look at your cells. You really need to redo that soldering or clean it up so solder is only each pad from ground, pin 1, and pin2. I'll tell you from now, if I see a single % in anymore of your posts, someone else can help you. Should the red line only going to pin 2 or should it bridged with pin 3 + 4? I interpret the circuit diagram that red is bridged with pin 2 + 3 + 4 And yellow with pin 1 and black goes to gnd.
Wayneo Posted April 15 Report Posted April 15 B- and G ground is cell 1 negative. Pin 1 is cell 1 positive and cell 2 negative. Yes, Pin 2 is cell 2 positive and needs to be bridged to 2-4 plus B+ like you have. But you need to clean it up. I also worry about all that exposed wire on the red. When you're done, use your multimeter and measure Ground + Pin1 (cell 1 voltage), then Pin1 + Pin2 (cell 2 voltage). 1
n82freak Posted April 15 Author Report Posted April 15 vor 32 Minuten schrieb Wayneo: B- and G ground is cell 1 negative. Pin 1 is cell 1 positive and cell 2 negative. Yes, Pin 2 is cell 2 positive and needs to be bridged to 2-4 plus B+ like you have. But you need to clean it up. I also worry about all that exposed wire on the red. When you're done, use your multimeter and measure Ground + Pin1 (cell 1 voltage), then Pin1 + Pin2 (cell 2 voltage). Cell 1 - 4.18V Cell 2 - 4,19V Cell 1 + 2 - 8,38V But in eScribe it shows complete wrong Volts.
n82freak Posted April 15 Author Report Posted April 15 vor einer Stunde schrieb Wayneo: I'm too tired to guess what Device Monitor shows
Wayneo Posted April 15 Report Posted April 15 Well, if that was after i said 3 hours ago, n82freak said: But you need to clean it up. I also worry about all that exposed wire on the red. When you're done, use your multimeter then open a Help Desk ticket. ⬇️ Link in my signature line. ⬇️
n82freak Posted April 16 Author Report Posted April 16 vor 11 Stunden schrieb Wayneo: Well, if that was after i said then open a Help Desk ticket. ⬇️ Link in my signature line. ⬇️ Yes i used a Multimeter an yes i cleaned... 😫
