replacing 250C board and screen, questions after assembly
Hello Modders'
I just replaced the 250C screen and board in my Hadron Pro, and everything soldered up nicely(first time really soldering) and plugged my LiPo battery in and everything came up. I noticed that withOUT my SC Ragnar tank on the mod, the resistance is showing at .66 ohms. ive done nothing more then solder, assemble, and connect it to a battery, then to my pc for escribe. so here's my questions.
1 Why am i see the .66 ohm on the mod without an atomizer? and where do i need to look?
2, Escribe is showing a SP update to 1.1 SP55.5 US, will this possible help with the issues in #1?
Any help is appreciated. and if you need to see anything or know anything, ill provide what i can.
Thanks Again
Richie
I'm not sure but I pulled the atty off my 250C and on the screen it still said 0.4 ohms. Did you tell it to measure again?
What does Atomizer Analyzer in EScribe say with no atty connected? It should have a question mark.
You have 8 profiles where the ohms and temp are written in case you set them up that way. You're seeing that with no atty.
No, but whaetver firmware you choose you should use the International version (more features)
@Wayneo Thanks, i didnt notice that the ohms on the first profile were already set it on escribe, so that fixes that. i think that im going to have to search out the int 55.1 SP as i dont see it in the list of SP's available to me thru escribe.
what are the more features that i would get? do they make that much more available over the US version?
thanks again
Use EScribes Device Monitor, note current voltage of each cell.If one or more is way lower it will not charge. If below 2.5 volts it willnot charge. Report back your findings.
Also make sure that you have it set for 4 cells.
i believe i found the root problem, which i didnt check. so im chalking it up to being blond. I did not check to make sure that all my solder points and areas around such were clean and clear. if you look at the board temp, that give the first clue as to what is going on. I didnt check the soldering around the 510 pads at the top of the board. I took a few pictures with my phone, and i have a crossing connection. so it looks like ill be resoldering the top again. hopefully this will clear up some / or all of the issues.
i will get some pictures of the area that im unsure on my soldering or that i think there might be a "short" possible. when i had the battery in and it was plugged in to my pc, just after that screenshot of the device monitor, i was smelling hot solder and see the temp get up to 102. give me a bit and i will add some pictures to let others see if they can help.
What does Atomizer Analyzer read with no atomizer attached?
Also do you happen to have a stand alone charger for 18650 batteries. If so I'll tell you how to use it to bring up the voltage on that #4 cell.
I was also wondering if you have a volt/ohm meter.
that's the thing. My battery (a 4S lipo) isnt being seen/read by the board. neither is any atomizer i attached. I have a secondary mod that reads the atomizer with no issue. the charger i have for my lipos is i believe dying, so im not able to charge my lipos there. I believe i have an ohm meter somewhere. so, right now the primary issue would be getting the board to read both an attached battery, and attached atomizer.
14 hours ago, rsandage said:
so this is what i see when Device Monitor is active.
The board is seeing the battery but it refuses to use it because of cell #4 being out of balance. Again, what does Atomizer Analyzer read with no atomizer attached?
It appears that you just might have two problems.
So what about that charger for 18650 batteries, do you have one?
Try this: connected to atomizer analyzer short the output and ground for the 510 using a screwdriver or wire and see if you can get it to read something.
(the spot that you suspected a solder bridge)
Edit: The board must be powered with battery for this to work.
So using a pre-built coil to create the short in the output gnd connection, while watching Atomizer Analyzer, there was no change to the ohms. then using a screwdriver, and no change. so what's that mean
Dude is that 510 positive able to move up and down if you push it with a screwdriver. If it's stuck down it won't make a connection. You might wanna test a few more attys. Usually if you see 5-11 puffs on a brand new mod, that shows the board was tested before being sent to you. Actually all boards are tested before shipping.
EDIT: You might be able to push the positive up from the inside of the mod, which is probably the easiest, to check.
Wayneo, Yes i can push the positive pin from on top of the 510 (like an atomizer would be attached to it) and on the under side, it returns to flush when i let up pressure from a screwdriver. but i can't push up from underneath. I hope thats what you're having me do.
EDIT The board i purchased was to replace the board that came with my Hadron Pro. So the non-board soldering was not touched.
Edited by rsandage
