TonyB Posted August 1, 2024 Report Posted August 1, 2024 I have a new mod that I can't seem to connect properly to my PC or Escribe (its not being seen by the PC). I thought it might be a cable issue as the USB C port is quite tight but I have tried filing down the plastic on one of my cables to allow the plug to go in fully but it still won't connect. The mod does power on when connected but its not connecting fully, the PC doesn't see it. I have tried a different quality cable as well but it still won't connect. I have the latest version of Escribe 2.0 SP57 installed. Other mods connect just fine. Thoughts on this please.
Wayneo Posted August 2, 2024 Report Posted August 2, 2024 What mod do you have? Maybe just flip the cable around where you insert it into the mod Try to plug in to your PC directly, not using a hub.
TonyB Posted August 2, 2024 Author Report Posted August 2, 2024 2 hours ago, Wayneo said: What mod do you have? Maybe just flip the cable around where you insert it into the mod Try to plug in to your PC directly, not using a hub. Hi Wayneo The mod is the Hussar C1 - just released. Its a cable issue as far as we can tell. The use their own USB C port and some cables work and some don't they are looking in to it to find out which cable to use. Not ideal but I have been in contact with them and they didn't realise that this was an issue.
Wayneo Posted August 2, 2024 Report Posted August 2, 2024 Good to hear you're working with them, especially now knowing it's not an Evolv data/charger board. Not all cables are the same and the gyrations just so that cable can be used in either orientation, is why I suggested you just try flipping it. While I only have a few 'C' devices, i have found that issue with cheaper non Apple cables with my phone. Good luck with that new boro mod. That's the new one with a 510 connector?
TonyB Posted August 2, 2024 Author Report Posted August 2, 2024 1 hour ago, Wayneo said: Good to hear you're working with them, especially now knowing it's not an Evolv data/charger board. Not all cables are the same and the gyrations just so that cable can be used in either orientation, is why I suggested you just try flipping it. While I only have a few 'C' devices, i have found that issue with cheaper non Apple cables with my phone. Good luck with that new boro mod. That's the new one with a 510 connector? Hussar are a good bunch, they will figure it out. Annoyingly I bought a decent quality cable from Anker and it didn't work, I did try and flip it. Yes its the Boro type device with the New Cimi connection system
Wayneo Posted August 3, 2024 Report Posted August 3, 2024 Please try to remember to update this post with the information from Hussar so other purchasers will know. 2
Ragintra Posted August 12, 2024 Report Posted August 12, 2024 Make sure to run program as administrator for Windows 10 OS.
TonyB Posted December 5, 2024 Author Report Posted December 5, 2024 Hussar replaced/repaired the USB C port. It their own design not one like the charging board/USB C that Evolv can supply. I am now able to connect to Escribe using an Apple USB C - USB C cable as supplied with my new iPhone but using a small adapter to allow connection to my PC USB A port, so I have been able to make my usual adjustments to wire types and profiles etc……Hooray! Strangely my USB A to USB C cable from Anker didn’t work. 1
dwcraig1 Posted December 5, 2024 Report Posted December 5, 2024 Might the "C" end of your Anker not going in far enough due to the port being recessed (if it is recessed) Edit: I just went back and read the 1st post, so much for the above comment I guess.
TonyB Posted December 5, 2024 Author Report Posted December 5, 2024 8 hours ago, dwcraig1 said: Might the "C" end of your Anker not going in far enough due to the port being recessed (if it is recessed) Edit: I just went back and read the 1st post, so much for the above comment I guess. 😄
