Hadron 250 plus (lipo battery version). Need to press the fire button 5 times to power it up. Both of my DNA devices will automatically power down after a period of inactivity, but the Hadron does it within a few (less than 5) minutes, instead of the original much longer delay. Regular use for a little over a year and the new behavior only started about two weeks ago. Never charged the cell in the unit, alternated between 2 cells that were recharged in an external charger.
That would be the Pro with the LiPo.
It sounds like you've changed the screen 'lock time'.  If you compare your two mods in escribe -> safety -> 'lock time' they should be different and you can  match your Hadron to the other. Then upload settings to mod.
Please reply either way with your findings.
Hooked it up to Escribe and while the autolock feature was still set to the default 240 minutes, upon disabling it and uploading the new settings, the problem has gone away. I'll probably just leave it off for now. Thanks for the helpful suggestions, Wayneo !
