Hello
Does anyone also know the max peak and max sustained imput current fields and cutt off in escribe should be ? And cut off
VTC6A 18650
VTC5D 18650
sorry for my English
THX
They are different depending on each board. From lower to higher in this order. 200, 250, 250C. Usually page 1 or 2 on the datasheet for each board. Your mod probably has the evolv defaults configured.
For battery specifics you should use Mooch's ratings/testings.
Edited: You were talking battery specs, I was answering board specs. 🙄
I've moved this post from the 'DNA 200 and 250' section to the 'Batteries and Charging' section.
I use a Prisma DNA 75c with 1 single 18650 battery
I've already done a lot of research but it's the jungle
I have a lot of trouble understanding the results of Mr Mooch's
THX
15 hours ago, gnrrico said:
I've already done a lot of research but it's the jungle.     I have a lot of trouble understanding the results of Mr Mooch's
I would follow Mooch's CDR rating, not the manufacturer rating.
BUT if you're going to be using 2 different batteries with different amperage ratings you decide what value to use. Do you use the higher rating and stress the lower rated battery or not.
The 2.75v value for 'cell soft cutoff' is a decent value for both, even though I've seen a 2.3v 'fully discharged' value for some batteries.
