1 amp, data/charging circuit board with vertically mounted micro B USB?
I bought into the Kizoku Techmod and what was delivered was for the most part complete garbage, maybe just the luck of the draw, I don't know.
It wouldn't even vape consistently in voltage mode so the somewhat intended circuit swap might just happen.
Not sure it's worth a DNA 60 swap honestly but the titled charging/data circuit board could make the task a lot easier. Odds are with the hole at the angle it is this isn't going to pan out well but pulling it off could be an accomplishment? I am my own trouble maker! 😁
Maybe a tiny breakout board would work.
With a portion of the mounting rails removed from the 60 it should stack on threaded rods off the stripped original circuit board leaving the switches to be tapped off the traces.
I have the threaded rod and nuts around here somewhere. It'll take a small screen display and some (fingers crossed!) minor modification of the 510's center pin. Yeah, that's another thing, some atomizers don't make contact being the center pin sits so low.
So please enjoy this opportunity to take part in my masochism, we can play together this way!   😆
The offensive item removed.
Edited by Podunk Steam
  • Podunk Steam changed the title to 1 amp, data/charging circuit board with vertically mounted micro B USB?
Outside of the U.S, probably stealthvape, or modmaker. Both in the U.K
Hopefully they'll use discreet packaging. During non pandemic times, I've had Royal Mail deliveries take anywhere from less than a week to two weeks to Canada 🇨🇦
Edit: You don't have to use the Evolv data/charging board. Others such as the Delro and SXK BBs have used others. They can be found at mcmaster-carr (www.mcmaster.com) in the U.S
Thanks Wayneo!
Being electronics I'd hope to manage this state side honestly, I'm not saying what I'm putting it into. 😉
I may have blazed through Stealthvape already and only seen the large screens if memory serves me.  I was wrong, Stealth does have them in stock.
2 minutes ago, Podunk Steam said:
You're a good man Wayneo!
Thanks, and this is before coffee. BTW, I've also been called the worst 🤣
5 minutes ago, Podunk Steam said:
.... just feeling kinda cornered these days ya know
Feels, man. Scary times ahead for you guys
