wrzt Posted February 19, 2021 Report Posted February 19, 2021 Hey all, I am looking for a battery discharge .csv for 2x Hohm LIFE 18650's for my Lost Vape Centaurus. Does anyone have one that they don't mind sharing, by chance? Thank you much! David
Wayneo Posted February 19, 2021 Report Posted February 19, 2021 I did a quick search up there ↗️, and there are > 15 mentions for them. You can do the same and see if a csv was ever created. Failing that, you have the ability to run your own 'battery analyzer', guaranteed accurate for your pair. Your mod only uses it for display of the charge level, and does not affect the operation of your mod at all Good luck and welcome 👋 2 1
wrzt Posted February 19, 2021 Author Report Posted February 19, 2021 7 hours ago, Wayneo said: I did a quick search up there ↗️, and there are > 15 mentions for them. You can do the same and see if a csv was ever created. Failing that, you have the ability to run your own 'battery analyzer', guaranteed accurate for your pair. Your mod only uses it for display of the charge level, and does not affect the operation of your mod at all Good luck and welcome 👋 Hey Wayneo, Thanks for the reply. Perhaps I'm not using the search feature properly, but I return 1800+ results that match "hohm life 18650", and if I pare it using the AND operator, I only see my post in the search results. Sorry if I'm being an idiot and doing something wrong - can you tell me what you are typing in the search field? Thanks man
Wayneo Posted February 19, 2021 Report Posted February 19, 2021 Man, IIRC I just used Hohm life and the 'all' option. Shows 8, I left out the extension. Thought it was more earlier, might try hohm csv as well. Edit: Don't beat yourself up, I wish 'all' was the default, personally. 1
