Silas Crowley Posted January 31, 2021 Report Posted January 31, 2021 Hello, and thanks for opening this thread- I've almost got a mod together and it's looking great, except I have one serious problem. For some reason- while the mod will turn on with just USB power, when the lipo is connected, it won't charge it nor will it connect to escribe. I can't connect the chip to escribe at all anymore. During a test run (before I soldered the 510 and external fire button) I was able to connect to escribe and updated the chip's firmware, but after everything was installed, it won't take anymore- it won't even charge the lipo. Has anyone has a similar issue? Everything looks fine on the chip, I took it out and inspected it, tried to clean up some of the joints in case that was the issue, but it still won't do data nor balancing charge on USB.
ThaDJ Posted Friday at 04:40 AM Report Posted Friday at 04:40 AM I'm having the same problem in an Odin with 2x 21700.
Wayneo Posted Friday at 02:20 PM Report Posted Friday at 02:20 PM Are you sure it's a DNA mod? Post a picture of the main working screen.
ThaDJ Posted 22 hours ago Report Posted 22 hours ago Yes, I put the board in myself. The photo attached is with fully charged batteries, it shows 4% at all times and after I click 5 times to turn on I get 5 red dots. So trying to connect to escribe to reset the board to ensure its set up as 2 x cell.
Wayneo Posted 15 hours ago Report Posted 15 hours ago Was that a new purchased board or just new to you? Check your wiring and solder joints down at the JST connector.
