DeadMan Posted August 27, 2020 Report Share Posted August 27, 2020 I've just changed the screen on my Paranormal. The replacement screen has a longer connector and is a right pain in the butt! I managed to squeeze it down but I noticed the little white plastic tab that poked out kinda fell off the old screen where it pokes out next to the firing button. No idea what it does so ignored it when putting it back together. Screen looks nice and clear. Not sure about the firing button. Seems a little less sensitive to use now but I won't be tearing it down again just yet. Protip: Don't rub your screen with your thumb too much like I did. It turned into a black monster in the middle of the screen. ;) They should have put a plastic protective shield over the exposed screen like on my Dovpo! Link to comment Share on other sites More sharing options...
Wayneo Posted August 27, 2020 Report Share Posted August 27, 2020 2 hours ago, DeadMan said: Not sure about the firing button. Seems a little less sensitive to use now Did you ensure the screen cable bend was away from the fire button? If you follow the link you'll see what I mean. Otherwise you might end up needing another screen after a while 1 Link to comment Share on other sites More sharing options...
DeadMan Posted November 3, 2020 Author Report Share Posted November 3, 2020 Yes it's away from the screen thanks. Link to comment Share on other sites More sharing options...
