TorturedZen Posted August 13, 2020 Report Posted August 13, 2020 (edited) First question...I've been trying to understand what determines the color for the graph lines in the Chart function. I have Power, Temp and Voltage options selected. When I view the graph it shows Temp in red, but Power and Voltage are both showing yellow. How can I correct this so the graph shows 3 different colors? Second question...in Theme Designer-Chart what is the function of the Time Bars option (defaults to 25) and the color box? Thanks in advance. Edited August 13, 2020 by TorturedZen
CMK Posted August 14, 2020 Report Posted August 14, 2020 vor 14 Stunden schrieb TorturedZen: First question...I've been trying to understand what determines the color for the graph lines in the Chart function. I have Power, Temp and Voltage options selected. When I view the graph it shows Temp in red, but Power and Voltage are both showing yellow. How can I correct this so the graph shows 3 different colors? => As far as I know, these colors cannot be changed Second question...in Theme Designer-Chart what is the function of the Time Bars option (defaults to 25) and the color box? Thanks in advance. => They are the vertical lines in the background of the chart; 25 indicates the opacity 1
TorturedZen Posted August 14, 2020 Author Report Posted August 14, 2020 10 hours ago, gwyar said: => As far as I know, these colors cannot be changed Well I hope that's not true because mine changed somehow. I'm positive my graph had 3 different color lines before. Maybe it's theme related so I'll have to check for any discrepancies. Thanks for the reply.
CMK Posted August 15, 2020 Report Posted August 15, 2020 https://forum.evolvapor.com/topic/69207-theme-designer-chart-device-monitor/?do=findComment&comment=921760 1
zark Posted March 8, 2021 Report Posted March 8, 2021 On 14.08.2020 at 23:06, TorturedZen said: Надеюсь, это неправда, потому что моя как-то изменилась. Я уверен, что на моем графике раньше было 3 разные цветные линии. Возможно, это связано с темой, поэтому мне придется проверить наличие неточностей. Спасибо за ответ. По этому поводу была дискуссия на другом форуме, цвета действительно нельзя изменить, это требование создателей Escribe, изначально была идея для анализа графиков, сохраненных в устройстве, с помощью Escribe, но потом это не было реализовано 1
