djgomes Posted August 11, 2020 Report Posted August 11, 2020 (edited) Good morning ... Recently my Finder DNA250C started to consume more battery than normal. I don't know what it could be but he has consumed about 1% per puff ... Is there something wrong. The batteries are new. Edited August 11, 2020 by djgomes
retird Posted August 11, 2020 Report Posted August 11, 2020 The Discharge Profile (as seen in EScribe) may be different from the the first theme you had and the theme you loaded recently. First thing to check..... if you saved the original Finder theme you can compare them...
djgomes Posted August 11, 2020 Author Report Posted August 11, 2020 28 minutos atrás, retird disse: The Discharge Profile (as seen in EScribe) may be different from the the first theme you had and the theme you loaded recently. First thing to check..... if you saved the original Finder theme you can compare them... Original theme is just me resetting the factory that will return.
