furnias Posted May 11, 2020 Report Posted May 11, 2020 Hi, i have a Neo Go from 67 Mods, with the DNA Go chip. I have done tests, and the Raplay mode don´t work with Kanthal or Ni80, but works with SS316L or NiFe48 But my question is, can i use NiFe48 with this chip? Is it safe? I Know Replay mode is not TC, but it works similar. I made a NiFe48 29ga, 2mm inner diameter 7.5 wraps 0.37 omh final coil. I set 10W and seems work well. Is this safe or this chip only works with normal wires? Thanks, and be safe!
Wayneo Posted May 12, 2020 Report Posted May 12, 2020 NiFexx has been used for vaping for many years. I use it occasionally, but I'm not going to say what's safe for anyone other than me. The GO board will allow Replay with pretty much any TC capable material/wire. Or it'll work like any other mod in straight watts.
furnias Posted May 12, 2020 Author Report Posted May 12, 2020 On 5/12/2020 at 12:16 AM, Wayneo said: NiFexx has been used for vaping for many years. I use it occasionally, but I'm not going to say what's safe for anyone other than me. The GO board will allow Replay with pretty much any TC capable material/wire. Or it'll work like any other mod in straight watts. Expand For a Spanish non english speaker, your answer needs a few seconds to be understod, but when you can, is perfect. If i understand the wire, i can go and play with it. Safe always depends of your knoledge. (KaA1, Ni80 are materials for VW. NiFe, SS, Ti are for TC) And, in this case, Replay mode works like a TC more or less, true? Thanks for take your time to write
Wayneo Posted May 12, 2020 Report Posted May 12, 2020 On 5/12/2020 at 1:44 AM, furnias said: And, in this case, Replay mode works like a TC more or less, true? Expand Yes. Enjoy your mod.
