bkorkidis Posted April 9, 2020 Report Posted April 9, 2020 Hello. I am new with dna250c and i need your help. I want to change language on my menu from German to English. How can I do that? Thank you and sorry for the stupid question.
Jetro Posted April 9, 2020 Report Posted April 9, 2020 (edited) bkorkidis I have written themes in two languages before. I do not know if this will work to reset a language on an exiting theme. If this does work it might not change anything other than the text on labels. Other fields might have to be renamed manually. Then again it might work perfectly. If this does not work you will have to manually rename each field. Try this, open the theme in theme designer. To do this click on the theme and click on "Edit". Look at the picture below. After selecting the language click the "Save" icon. Then select each screen from the screens at the right of display. Check the names, hopefully they changed to English. If this works please let me know, I have never tried it before. JT Edited April 9, 2020 by Jetro 1
Jetro Posted April 9, 2020 Report Posted April 9, 2020 (edited) This is the Save button. Also no question is stupid, the only stupid question is one that is not asked. Jt Edited April 9, 2020 by Jetro
zazzgu198 Posted April 30, 2020 Report Posted April 30, 2020 (edited) В 09.04.2020 в 21:39, Jetro сказал: This is the Save button. Also no question is stupid, the only stupid question is one that is not asked. Jt thank you for your help I was also looking for how to change the language and now thanks to you I can do it Edited April 30, 2020 by zazzgu198
