leea12345 Posted March 5, 2020 Report Posted March 5, 2020 (edited) First i would like to say thank you for help i have received , i just am getting frustrated now . Please can you tell me where i am going wrong At this moment i am trying single wire as i was informed that works best in the dna for tc ? . I have a 8 wrap 22 gauge ss316l at 0.34 resistance . I placed the coil in and wicked, i then opened e scribe and read resistance and i locked it at room temp . . I am running at 27w and around 400F pre heat is on set at 75w in e scribe and punch is set at 5 on my device Do these settings seems ok or wrong ? Now if i decide to reset the resistance from the device menu and then fire , for some reason it seems to pump out the pre heat value of 75w , sometimes and of course bad vape burnt cotton, i really am confused. Should i always use e scribe for this ?? I also find i get dry hits is i turn the wattage up, on the device with the above settings , i really am confused Should i not use purchased fancy coils for ss316l in a dna , does the coil need to be spaced ? and should i call the evolve service centre i have been given as there could be an issue with the board ? I will just add i did use the atomiser analyzer and the resistance looks very steady , everything is tight, connections look good Thank you, pleas help Edited March 5, 2020 by leea12345
zark Posted March 5, 2020 Report Posted March 5, 2020 (edited) 2 часа назад, leea12345 сказал: Now if i decide to reset the resistance from the device menu and then fire , for some reason it seems to pump out the pre heat value of 75w , sometimes and of course bad vape burnt cotton, i really am confused. Should i always use e scribe for this ?? Возможно я не совсем верно понял переведенный текст, но мне кажется это проблема с theme, которую Вы используете. Попробуйте установить тему по умолчанию или тему автора с хорошей репутацией. Edited March 5, 2020 by zark
