Seek Posted January 2, 2020 Report Posted January 2, 2020 Is it possible to make a condition that could happen when I'm firing in TC and the realtime temperature of the coil gets above certain point, or even better to the set temeperature? I have a massive dry coil that I want to heat up to a high temperature, even on 100W it takes several seconds. I'd like visual feedback of a sprite changing when it reaches the desired temeprature so I can start inhaling. At first I wanted a realtime puff timer but even that is not available. There jsut seem to be no way at all to time your hit except the fire LED color gradients.
Seek Posted January 2, 2020 Author Report Posted January 2, 2020 (edited) It doesn't use e-liquids. It's a dry herb vaporizer, the coil works like in a blowdryer heating up the flowing air through it and then the air evaporates the material above the coil. But that's besides the point, is it possible to make such a condition? Edited January 2, 2020 by Seek
retird Posted January 3, 2020 Report Posted January 3, 2020 This is an Evolv e-cig/e-liquid forum... you might go to an herb forum for help....
Seek Posted January 3, 2020 Author Report Posted January 3, 2020 I don't want help with the coil, I want help with the escribe theme designer. Which I think I'm in the right place for. MY question could apply to liquid atomizer too, they just heat up quicker...
retird Posted January 3, 2020 Report Posted January 3, 2020 The DNA technology is designed as a personal vaporizer. TC regulates temperature for the vaporization process of a liquid to a desired temperature. Your intended use is not the intended use of a DNA.
retird Posted January 3, 2020 Report Posted January 3, 2020 You can start a ticket with Evolv and see if they want to answer your question.... we do not work for Evolv...... https://helpdesk.evolvapor.com/index.php?a=add&category=1 1
