Eviscerat0r Posted August 22, 2019 Report Posted August 22, 2019 My 166 survived a hard fall while it was charging. The USB port became fully unusable. Is there any way to replace it? It would be a shame to change the entire mod just because of broken USB.
retird Posted August 22, 2019 Report Posted August 22, 2019 You can replace the board.... https://www.evolvapor.com/shop If you are really skilled in working on circuit boards, and the board is not damaged, I guess you could replace the usb connector....
Eviscerat0r Posted August 22, 2019 Author Report Posted August 22, 2019 14 минуты назад, retird сказал: You can replace the board.... https://www.evolvapor.com/shop If you are really skilled in working on circuit boards, and the board is not damaged, I guess you could replace the usb connector.... Thanks for your reply. Well, the board is also pretty expensive. I had fully disassembled the mod, board is not damaged. Guess I actually can replace it, but i don't have equipment needed to do so. Anyway, i'll think of something.
retird Posted August 23, 2019 Report Posted August 23, 2019 You might start a ticket with Evolv and explain what happened. Tell them you think the usb connector just needs to be replaced. See what they say. Also tell them the name of the mod and how long you have had it. Here is the link.... https://helpdesk.evolvapor.com/index.php?a=add&category=1
Eviscerat0r Posted August 23, 2019 Author Report Posted August 23, 2019 31 минуту назад, retird сказал: You might start a ticket with Evolv and explain what happened. Tell them you think the usb connector just needs to be replaced. See what they say. Also tell them the name of the mod and how long you have had it. Here is the link.... https://helpdesk.evolvapor.com/index.php?a=add&category=1 Thanks for the advice.
