DNA 250c issue
Bama boy 1
 Share
After putting in the batteries what happens when you press the down button and then the up button? If that moves the choice between yes and no (new/old, etc depending on the theme you have) then just select (middle button) your choice. If you are only changing batteries while using the device then you probably don't need to select "new coil".
 Share
