TimWiseman9000 Posted July 21, 2019 Report Share Posted July 21, 2019 Hi, i have a number of both 250c and 75c devices and use them all with Replay with no problem. My Hcigar 75c i have happily used with Replay for some time then suddenly it's as if replay is idle and the box that would usually say "save puff" constantly stays blank. I have tried the device with escribe but that seems to suggest it is set-up as usual so it's a mystery. Any ideas? Link to comment Share on other sites More sharing options...
Wayneo Posted July 21, 2019 Report Share Posted July 21, 2019 Have you used Device Monitor to check that the ohms are actually rising during your puff? Is it new material(wire) you're using, and can you describe your coil. Link to comment Share on other sites More sharing options...
TimWiseman9000 Posted July 21, 2019 Author Report Share Posted July 21, 2019 It suddenly after 4 hours started working again. The coil is a SS316 3 core parallel, it wasn't actually a new coil i had simply dry burned it and changed the wicking and when i then went to use it on the HCigar it wouldn't allow me to save puff for the next about 4 hours. I have cleaned coils and re-wicked this way many times and it's never effected Replay before. During the period it wasn't working i did try the RTA on other devices and Replay worked fine just not the HCigar and then suddenly when i had given up all hope it started working as if nothing had ever happened. Link to comment Share on other sites More sharing options...
Wayneo Posted July 21, 2019 Report Share Posted July 21, 2019 Good to hear it's back up and running for you. Other than a possible resistance mismatch, I have no idea. Link to comment Share on other sites More sharing options...
