Hello, why do evolv boards that use escribe have the option (or mandatory I dont know) battery discharge profiles? Why do we have to look for dual or triple or lipo discharge profiles and apply it to the mod? Is the watt hour setting enough? All other boards deal with this on their own without having the user to define these values
Specific discharge curves are NOT MANDATORY. You can use the default if you want, just fine. ALL batteries are NOT created equal. BUT if you want the most accurate battery icon and %,  be able to fine tune parameters for your vaping style, you have the ability to do that.
Depending on the board, Wh settings are not required.
