I've tried many times, done SP updates, reinstalled and yet nothing. I oce got a message something about firmware fail. The mod still works, but I'm unable to upload a csv now. I don't knoq what to do. It seems to recognise the mods name, but not conenct at all. Anyway to do a hard reset? I've looked for help, but found nothing.
I click the connect to download button, choose the mod that it recognises, but then the program stops responding.
Manafged to issue a "hard reboot", but still no connectivity.
Using Windows 10
When uploading latest SP came up with error report:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
A.WMO: Exception of type 'A.WMO' was thrown.
   at A.DPP.GPP.VY(WPP )
   at A.DPP.TI(WPP )
   at A.NVF.Q(MMO , Object , Boolean& , Boolean , OTI )
   at A.NVF.GVF.Q()
   at A.NVF.Q(GLY , Object , Boolean , Boolean& , Boolean , OTI )
   at A.NVF.Q(Func`1 , Boolean& , Boolean , Boolean , GLY , OTI )
   at A.NVF.Q()
   at A.VSF.<>c.I(Object , EventArgs )
   at A.OQA`1.NX()
   at A.OQA`1.QT()
   at A.FQA.BQA.I()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3416.0 built by: NET472REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
DEScribe
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/EScribe.exe
System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
DEScribe&
    Assembly Version: 1.0.0.0
DimensionEngineering.Common.Platform
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Platform.DLL
DimensionEngineering.Common.Platform&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Platform.dll
DEScribe.Branding
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.DLL
DEScribe.Branding.Evolv
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.Evolv.DLL
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.DLL
DEScribe.Branding.Evolv&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.Evolv.dll
DEScribe.Branding&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.dll
DimensionEngineering.PluginApi
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.PluginApi.DLL
System.Xml.Linq
    Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Core
    Win32 Version: 4.7.3362.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
DimensionEngineering.Common&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.dll
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.DLL
DimensionEngineering&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.dll
DimensionEngineering.PluginApi&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.PluginApi.dll
DimensionEngineering.Common.Windows
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Windows.DLL
DimensionEngineering.Common.Windows&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Windows.dll
System.Windows.Forms
    Win32 Version: 4.7.3324.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
DevExpress.Utils.v18.1
    Assembly Version: 18.1.3.0
    Win32 Version: 18.1.3.0
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DevExpress.Utils.v18.1.DLL
DevExpress.Data.v18.1
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DevExpress.Data.v18.1.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
BouncyCastle
    Assembly Version: 1.8.1.0
    Win32 Version: 1.8.15362.1
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/BouncyCastle.DLL
DEScribe.Core
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Core.DLL
DEScribe.Core&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Core.dll
DEScribe.UI
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.UI.DLL
DEScribe.UI&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.UI.dll
System.Security
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
SecondLanguage
    Assembly Version: 1.0.4.0
    Win32 Version: 1.0.4.0
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/SecondLanguage.DLL
SecondLanguage&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/SecondLanguage.dll
ICSharpCode.SharpZipLib
    Assembly Version: 0.86.0.518
    Win32 Version: 0.86.0.518
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/ICSharpCode.SharpZipLib.DLL
EquationParser
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/EquationParser.DLL
EquationParser&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/EquationParser.dll
DevExpress.XtraEditors.v18.1
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/DevExpress.XtraEditors.v18.1.DLL
TrueTypeSharp
    Assembly Version: 1.0.5.0
    Win32 Version: 1.0.5.0
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/TrueTypeSharp.DLL
HidSharp
    Assembly Version: 2.0.5.0
    Win32 Version: 2.0.5.0
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/HidSharp.DLL
HidSharp&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/HidSharp.dll
SaberUpload
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/SaberUpload.DLL
SaberUpload&
    CodeBase: file:///C:/Users/Chris/AppData/Roaming/Evolv/EScribe%20Suite/SaberUpload.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Can't find a single link to SP page anywhere.
Edited by Renegade-86
Can't any wire be used in TC mode? All electroconductive materials have a temperature/resistance coefficient, so they can at least technically. There are also quite a few sites showing TCR for Ni80, but no CSVs to be found for Ni80 mesh. I tried with a SS mesh CSV on this site, but wouln't work. Is there any tutorials on how to set up a CSV?
In the end I just decided to have a go myself as I couldn't find anything online. I used the device monitor to note the resistance at various set temperatures and edited the graph accordingly. I'm not sure how this would work as it sounds like using a ruler to check the accuracy of the same ruler. I managed to make the graph, but couldn't get all the temperature points so I had to make it up in parts. It seems to vape alright, but not sure if there's a better way to do it. Is this how it's done or is there a tutorial you can give on doing it properly?
I'll attach the CSV.
Ni80 100Mesh.csv
No. N80 does not change enough for it be used in TC. SS3xx increases around 20% (in our vaping temp range) and that's about the lowest TCR material.
Hohm mods in the past claimed they could do it (even kanthal), but they're longer in the mod business
Not that I'm aware of. And it just won't work.
You could if you want, find the specs for N80, and IIRC if there's a Mechanical section they might post the rise in ohms at diff temps, and from that craft a TFR file if you understand what you're doing, but it would still not work IMHO. Even the DNA250C board (flagship) will struggle with it, (dubious coil) in Replay and not supported.
  • 4 weeks later...
