Blaize Posted May 14, 2019 Report Share Posted May 14, 2019 Hi all. I have googled and searched here and all the info I have found seems to be out of date or doesn't work. I would like to change my wattage increments to be at least 1 watt, if not 5 or 10. I cannot seem to make this change. Anyone want to walk me thru it? I found the screens tab in theme designer, and clicked on main screen, then the wattage window, and finally the little "c" button in the panel to the right of the screen. That gives me decimal and step size adjustments. I set those to 0 and 5 respectively, but still it goes .5 watts at a time. Any ideas what I am doing wrong? Link to comment Share on other sites More sharing options...
Wayneo Posted May 14, 2019 Report Share Posted May 14, 2019 That should have worked. Decimal to 0, step to 5. Everywhere you can find it in the theme. Then apply, upload settings to mod. Link to comment Share on other sites More sharing options...
Blaize Posted May 14, 2019 Author Report Share Posted May 14, 2019 Thanks man, it did in the end. After posting that post I unplugged the mod and started playing with it, found that my changes had worked in the wattage profile, but not the replay one. I simply didn't realise they were set differently in the theme designer. Went back in, found the tab to get me into the profile I wanted, changed it to 0 and 5 there, now works as it should. Thanks for the reply though, good to hear I am not going totally crazy. Link to comment Share on other sites More sharing options...
