debatedude Posted April 25, 2019 Report Posted April 25, 2019 It’s been a while since I owned a DNA chipped mod. My first one was back in late 2016; the Cartel X-200 with the Evolv DNA 200 chip. Unfortunately, the mod died in 2017 (issues with Cartel’s build, not the chip). I’m now the proud owner of a Think Vape Finder 250C mod with the new 250C board. Now the question: I use nichrome 80 wire (various gauges) in wattage mode only (no TC). I remember having to load nichrome files into Escribe so that I could set the proper material in my Cartel mod. Do I need to do this with the 250C board in the Finder mod? And if I do, is just one file or a file for each gauge of wire I use? And…where can I find these files, if needed? In advance, thanks for any help, or for pointing me in the right direction.
Wayneo Posted April 25, 2019 Report Posted April 25, 2019 Material files are independant of coil ID, wraps, number of wires, etc. So, only the material itself. For straight watts, no material file is needed at all, for any material type. What you remember was for an old cheat. There are already some material files on your mod, but you can also get/create some on steam-engine. IMHO you should really try out Replay with a TC build. Still, no material file needed, with the benefit of dry hit protection. 1
debatedude Posted April 25, 2019 Author Report Posted April 25, 2019 11 minutes ago, Wayneo said: There are already some material files on your mod, but you can also get/create some on steam-engine. I use steam engine quite a bit. I notice that the only CSV file is generates is for the DNA 200. Will that also work on the DNA 250C?
Wayneo Posted April 25, 2019 Report Posted April 25, 2019 Yessir. The files are compatible/interchangeable across DNA 60, 75, 75C, 200, 250, 250C ...... and I hate to publicly say this, but even Arctic Fox 1
