Vapors Tongue Posted April 6, 2019 Report Posted April 6, 2019 whenever the next update comes along i would like to see the option of setting , measuring and locking resistance through all profiles , so when you lock your coils resistance that's registered in all profiles
Pphish Posted April 10, 2019 Report Posted April 10, 2019 On 4/6/2019 at 4:13 AM, formula 1 said: whenever the next update comes along i would like to see the option of setting , measuring and locking resistance through all profiles , so when you lock your coils resistance that's registered in all profiles Not going to happen, and here is why: Evolv designed each profile to have readings independent of one another, this way each profile could theoretically represent a different atomizer. With all the variables that one can change in a profile, it's actually quite nice to be able to pre-set a profile so one can quickly put on a new atomizer and with a couple clicks be ready to have an entirely different vaping experience. You are aware that you could just lock in the cold resistance into all of your profiles and that can literally be done without even having to use a computer! It would undermine the entire reason the profiles are there in the first place.
Vapors Tongue Posted April 10, 2019 Author Report Posted April 10, 2019 4 hours ago, Pphish said: Not going to happen, and here is why: Evolv designed each profile to have readings independent of one another, this way each profile could theoretically represent a different atomizer. With all the variables that one can change in a profile, it's actually quite nice to be able to pre-set a profile so one can quickly put on a new atomizer and with a couple clicks be ready to have an entirely different vaping experience. You are aware that you could just lock in the cold resistance into all of your profiles and that can literally be done without even having to use a computer! It would undermine the entire reason the profiles are there in the first place. option would be great wouldnt it either to enable or disable that function , if you swap from one profile to another Temp to Replay mode and Watts - it wouldnt be to hard to enable or disable the feature - not many people have a few atomizers in their pockets at anyone time and with using SS coils they get warm and dont give a cold reading
