Yea I'm getting burnt hits after 4 days of use. Not vaping hard either. It's really harsh cannot use pod have to discard to avoid the burnt taste. Also with even a new pod, cannot use blue setting very long without getting the burnt hit, having to go to white right away. These are too expensive to change out after 4-5 days. Does anyone know the remidy? Does using escribe help? What do I do?
hi which coil are u using?go to the setting and reduce the boost to 0 and replay warmth to 1 it should be fine but for me i have to change the pod after 3 or 4 days but i consume around 1000 puff which i think its good to change the pod after 1000 puffs  and i am not reducing the boost and warmth as when i changed them i felt  that the hit is not good especially with the 0,5 coil it worked well with the 0.25
I'm using .25 and I don't know what you mean by reduce boost to 0 and replay warmth to 1 and it should be fine...is this done by escribe. I'mafraid of using escribe because i hear it is causeing problems by freezing functioning of the orion.
Monir, I heard someone say to set all of the boosts to 0 and replay warmth to 1 is that correct? Let me ask..when you change to these recomended settings does it change the amount of flavor or size of the clouds it produces? Also I've been choking and coughing alot with these factory settings do you know why?
Yes these are the setting i told you about .actually i faced the same issue coughing but not because of the setting actually its because of the coil the 0.25 .i am fine now with the the 0 5 coil no coughing.did u try it?
FYI   The 0.25 ohm coil is for DL  (Direct Lung inhale) and the 0.50 ohm coil is for ML (Mouth to Lung inhale). The Orion automatically detects which coil is being used...
Monir thanks for the feedback. I changed the settings and no more burnt taste. We'll see how long the pods last now. Also getting the same amout of flavorand big clouds and alot less coughing.
