Stevie23 Posted January 29, 2019 Report Posted January 29, 2019 (edited) I just got a therion dna75c squonk and it is reading resistance so wrong. My coils on ohms reader is 0.28 and the reading on my therion is .530. Why won't it read correctly and Everytime I lockt thenunlock device it asks if it's a new coil at this price there is no way this is normal my coils are taking forever to heat up like 3 to 4 seconds to get good vapor. Please help Edited January 29, 2019 by Stevie23 Misspelling
dwcraig1 Posted January 29, 2019 Report Posted January 29, 2019 If I were to guess I'd say the 510 ground connection is poor, for what ever reason. Since it's new are you able to return it. If not open a ticket with Evolv and they will most likely take care of it for you. https://helpdesk.evolvapor.com/index.php?a=add&category=1
zark Posted January 29, 2019 Report Posted January 29, 2019 Usually in the helix menu you can manually change the resistance. If you are confident in the resistance of the spiral, then put the value that suits you. During thermal control, the resistance should be locked, it is desirable to lock the resistance in any mode.
Stevie23 Posted January 29, 2019 Author Report Posted January 29, 2019 1 hour ago, dwcraig1 said: If I were to guess I'd say the 510 ground connection is poor, for what ever reason. Since it's new are you able to return it. If not open a ticket with Evolv and they will most likely take care of it for you. https://helpdesk.evolvapor.com/index.php?a=add&category=1 I bought it used so idk if opening a ticket will be possible
dwcraig1 Posted January 29, 2019 Report Posted January 29, 2019 Give it a try, pretty sure it will work out.
Stevie23 Posted January 29, 2019 Author Report Posted January 29, 2019 14 hours ago, dwcraig1 said: Give it a try, pretty sure it will work out. I tried because I bought it used they won't fix it. You Kno where I can buy a lost vape bf replacement 510 connector? I tried to go-to their website but it doesn't work it's like they deleted it
