ArminF Posted December 27, 2018 Report Posted December 27, 2018 Hello, could not find much detail about it. The PDF just states pre heat in TC mode on the DNA60. Would Preheat work on an Kanthal or NiChro Setup? thank you very much.
Wayneo Posted December 27, 2018 Report Posted December 27, 2018 No. In 'DNA speak' you can only pre heat a TC material. But all is not lost. You can do a Boost Punch with any material in watts/wattage/power mode. It's a value from 1-11, which is a 1 second boost of the watts you've set. (effectively pre heating your coil)
ArminF Posted December 28, 2018 Author Report Posted December 28, 2018 @Wayneo thank you for your reply. Thats what i was looking for. Was not sure if the 60 is offering the option.
Wayneo Posted December 29, 2018 Report Posted December 29, 2018 On 12/28/2018 at 2:16 AM, ArminF said: Was not sure if the 60 is offering the option. Yeah, with the latest firmware. I surmise that the datasheets once published don't get updated. Some mods with the 60 chip don't have USB natively so be aware of that. 1
ArminF Posted January 15, 2019 Author Report Posted January 15, 2019 @Wayneo Got the chip and updated it right away. Also found the Punch mode for Wattage settings. The scale is from 1 to 11. Is this somehow percentage or watt which get added? And you might can answer me this. Am i able to reduce the profiles from 8 to 4? Disable the unused ones? thank you!
Wayneo Posted January 15, 2019 Report Posted January 15, 2019 1 hour ago, ArminF said: The scale is from 1 to 11. Is this somehow percentage or watt which get added? Yes. It's been over a year since I did my testing and never used it, so I have forgotten all the constraints. But you can see them via Device Monitor.
ArminF Posted January 16, 2019 Author Report Posted January 16, 2019 Thank you @Wayneo. Will sit down and check with the device monitor.
