aatoo Posted December 12, 2018 Report Posted December 12, 2018 Can someone please help me find the CSV for 3x Sony VTC5A for the HCigar VT250s? (DNA 250) For some context, I'd been using this mod with 2x Hohm Life 18650s, but couldn't find any discharge profiles for those. Moved those batteries to another mod and got three new VTC5As to use with this mod. And now I can't find any CSV for the VTC5As either. Any help will be greatly, greatly appreciated.
aatoo Posted December 13, 2018 Author Report Posted December 13, 2018 Thank you so much! Do you also know if I should change the values for Max Peak & Sustained Input Currents? Right now it says 28A in both.
retird Posted December 13, 2018 Report Posted December 13, 2018 1 hour ago, aatoo said: Thank you so much! Do you also know if I should change the values for Max Peak & Sustained Input Currents? Right now it says 28A in both. No.......... here is a Datasheet for the DNA250. It has minimum, typical, and max values specs' and much more info you might read.... https://downloads.evolvapor.com/dna250.pdf
Lanzarotechris Posted December 13, 2018 Report Posted December 13, 2018 9 hours ago, aatoo said: Thank you so much! Do you also know if I should change the values for Max Peak & Sustained Input Currents? Right now it says 28A in both. Hi aatoo, according to my factsheet of the Sony VTC5A it has a sustained output current of 28 A and a max peak of 35 A. If you use different batteries always check the datasheets for this values ! There are some useful websites where you can find detailed information and tests for the batteries. I use this website( http://www.dampfakkus.de/ ) but unfortunately it is in german. But maybe you can use a translation tool to find what you're looking for if needed.
aatoo Posted December 14, 2018 Author Report Posted December 14, 2018 Thank you, and even more for the amazingly useful website that you mentioned. Translated version works just fine for me!
