Hi,
I want to close the topic with percentage problems.
If you see wrong percentage, first of all check voltage in mod, than check percetage in other mod.
If it`s showing wrong percentage, you must save your battery csv, and edit it in excel and put it right in the mod again.
There is voltage and percentage box. I suggest to make from 0 to 100% (10,20,30%... 10 boxes) and divide voltage. If your battery max is 4.2v so start from 100%-4.2 or 4.19 and then others. I`m attaching my default HG2 profile using this method, you may edit it, depends on max voltage. Mod picking up measuring great after that (99-98% showing good).
Sorry if i was obvious, it must be pinned as soulution to this threads.
Done on Lost Vape Paranormal 250c
battery default.csv
Edited by NotMuchOfaVaper
