Guest Posted December 3, 2018 Report Posted December 3, 2018 (edited) As the title says, is it possible to Permanently save the Usb charge current on a DNA250 (not color)? Ive got a 1300mah lipo installed and ive noticed if i charge at the full 2amps the charge indicator on the mod keeps turning off and on. Im guessing its thermal regulation? If i set the charge current in device monitor to 1.7amps, the charge remains solid but i cant get it to permantly save it when i try charging from a wall adapter. If it's not possible to permantly set the charge current is it safe to charge at the full 2amps with it been a 1300mah battery or should a buy a usb wall adapter that only goes upto 1.5 amps or something similar? Thanks Edited December 3, 2018 by jimlad
dwcraig1 Posted December 3, 2018 Report Posted December 3, 2018 This might not quite be the answer that your looking for but I have the same problem. The way I deal with it is to use a cable of "lesser quality", it only happens to me with my best cables. 1
Wayneo Posted December 3, 2018 Report Posted December 3, 2018 3 hours ago, jimlad said: .......... is it safe to charge at the full 2amps with it been a 1300mah battery That's 3 separate cells sharing the full charging rate. So effectively that's charging at just under .7A per cell.
Guest Posted December 3, 2018 Report Posted December 3, 2018 Usually when charging at the full 2 amps, it'll charge ok for maybe 20 minutes and then the charge will start turning off and on (mods still powered up ok and fires), or dropping to .5 ish amps then returning back upto 2amps again for a few seconds.
